2008 avenger SE oil leaking
Hello members ! I'm requesting some help !! I would like to know what part do I have to change to stop the leak ! I changed the oil pan gasket 1 moth ago and I'm sure the leak is not coming from there !! I see some dirty oil just behind the engine in the upper part ! I say the probably can be the engine head gasket ! But I'm no sure if it's something common ! Or the leak can be from other part ! (Oil came down from behind the engine from right to left (looking from the front) and goes down behind the timing belt and ends in the left button part of the oil pan ! ) the leak is like 4 to 8 drops in the entire day !
108 k miles / 2.4 cc /
Thank you !
Thank you !
