2008 Avenger 4cyl P0017
Hello, I've been battling a issue on a family car. Shes driving a 08 dodge avenger 4cyl. Has had it for a couple years. Its well taken care of and oil changes all exactly on time. I did the last one myself so I know forsure the oil is good and the right viscosity. I have changed the cam and crank sensor. The engine light keeps coming back on and I am told when getting on the high way it sounds like its struggling. What do you guys think? The car is clean looking it doesn't look like anything was messed with under the hood.
Thanks for your time,
Kevin
Kevin
Hi kevilay,
Welcome to the forum. Sorry to hear about your concern. I found a TSB (18-018-07 REV. A) that may be related to your concerns. I recommend bringing your vehicle to an FCA dealership and referencing this TSB.
TSB 18-018-07 REV. A
SUBJECT:
Flash: MIL Illumination with DTC's P0016, P0017, P000A, or P000B
OVERVIEW:
This bulletin involves selectively erasing and reprogramming the GPEC Powertrain Control
Module (PCM) with new software, **verifying oil pressure specifications**, replacing the
intake and exhaust oil control valves (OCV), and replacing the engine oil and filter.
CAUTION: VEHICLES EQUIPPED WITH A CVT TRANSMISSION MUST HAVE THE
TRANSMISSION CONTROL MODULE (TCM) CHECKED FOR THE LATEST
SOFTWARE LEVEL WHENEVER THE PCM SOFTWARE IS UPGRADED. IF
NEWER TCM SOFTWARE IS AVAILABLE, IT MUST BE INSTALLED.
MODELS:
2007 (JS) Sebring
2007 - 2008 (JS) Avenger
2007 (MK49) Compass
2007 (MK74) Patriot
2007 (PM) Caliber
NOTE: This bulletin applies to models equipped with a 1.8L, 2.0L or 2.4L gasoline
engine (Sales Code EBA, ECN or ED3) on PM/MK models built before
February 20, 2007 (MDH 0220XX) and JS models built before March 5, 2007
(MDH0305XX).
NUMBER: 18-018-07 REV. A
GROUP: Vehicle Performance
DATE: May 30, 2007
SYMPTOM/CONDITION:
Some customers may experience MIL illumination. Performance issues may or may not be
experienced.
The technician may find the following DTC's:
• P0016-Crankshaft-Camshaft Timing Misalignment-Bank 1 Sensor 1.
• P0017-Crankshaft-Camshaft Timing Misalignment-Bank 1 Sensor 2.
• P000A-Bank 1 Camshaft 1 Position Slow Response.
• P000B-Bank 1 Camshaft 2 Position Slow Response.
The DTC's may be intermittent and difficult to duplicate.
SUBJECT:
OVERVIEW:
MODELS:
2007 (JS) Sebring
2007 (MK49) Compass
2007 (MK74) Patriot
2007 (PM) Caliber
(MDH0305XX).
DATE: May 30, 2007
SYMPTOM/CONDITION:
experienced.
