door ding ding ???
Old 11-09-2008, 09:24 PM
Purpleheartx2's Avatar
Purpleheartx2
Purpleheartx2 is offline
Default Heres the answer.
https://dodgeforum.com/forum/showthr...t=door+dinging
Old 02-17-2016, 07:22 PM
dodgy2004's Avatar
dodgy2004
dodgy2004 is offline
Thumbs up door ding ding ???
Have a 2004 Dodge Caravan. Turn off engine and open door and the dinging started with the door open light lit on the dash and the rear pilot light on the ceiling was lit. Closed the door and the dinging stopped but rear pilot light stayed on. Turns out it was the dash light controller or that spin dial to the left of the steering wheel. When I adjusted the dash light to the correct setting the dinging stopped and all is well.
Old 07-20-2017, 06:25 AM
crazybarb's Avatar
crazybarb
crazybarb is offline
Default 2015 dart
is my car supposed to ding ding ding when the trunk is left open and i start to drive? Are the doors supposed to ding ding ding if i open a door when the car is in motion?
Old 01-12-2019, 12:53 PM
Jordan Armstrong's Avatar
Jordan Armstrong
Jordan Armstrong is offline
Default Disabling door chime
The sensor that says the doors shut is in the door latch..just move it to the closed position with door open and ur good til ya shut it again
Old 06-25-2019, 09:22 AM
bohnjerry's Avatar
bohnjerry
bohnjerry is offline
Smile [OP] - I solved it!!
Hello.. Thread OP here.. I solved it last night....
I checked the buckle to validate that ground to the green wire with gray tracer is open when unbuckled.. closed when buckled..
I checked continuity between ground wire (small black) to chassis ground.. all set.. so I figured it was "upstream" on the green wire/gray tracer....
I happened to see when I was working on things.. a green wire with a gray tracer coming down and away from the lower dash to a white module just to the left of the e-brake pedal. I nicked a piece of insulation off it and used a wire to ground it... Seat belt light went off!! I then proceeded to splice in a wire to this one and a permanent ground.
Quick Reply: door ding ding ???
