Vehicle: 2000 Bright White Single Cab Dakota R/T 5.9L 360ci
Buying a 2nd Gen Dakota? Look HERE for things to check before buying!
This thread is very simple, your about to buy a Dakota and you want to know the things to look at before you purchase it... Follow the list below and details on how you can tell it needs to be replaced.
Thank you, and if anyone else wants to add to this post please make a post with the info and ill edit this post as we get more info.
For now ill cover the Basics.
Upper and Lower Ball Joints - If wheel rocks back and forth, or the joints are ripped and falling apart they are bad
Belly Pan Gasket 3.9, 5.2 and 5.9 only - Look into Thottle body if you see any oil it needs to be replaced
Transmission Shift Problems 1-2 or 2-3 (Autos only 46re) - Govenor Sensors need to replaced or rebuilt (Transgo makes a Kit) bands need adjustment or replaced, short in tranny harness, I would recommend a Stage 1 or 2 Transgo Shift Kit to correct all the OEM Problems with the Auto Trans
Water Pump - Check for corrosion/white stains on the bottom of the water pump it likes to leak
Coolent Temp Sensor - Small Sensor on the Intake manifold easy to replace and cheap
Thottle Body Sensors IAC and TPS - Both like to clog up or stop working or go out and cause the truck to die, idle wrong, surge, ect...
O2 Sensors - All of Cryslers Cars/Trucks LOVE to run rich, causing our o2s to crap out faster then normal. Bad Fuel Economy, Rough Idles, CELS can be thrown for this.
more to come....
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
__________________ November 2008 Truck Of The Month
Cam, pushrods, and .600lift springs on order!
Sponsored Links
Registered users do not see this ad. Click here to register for free!
Location: Lancaster, PA (Home), Williamsport, PA (School)
maybe you should edit it for like years and engines/trans types because the belly pan gasket is on the 5.2's 5.9's and the tranny problems happen more with the older style than the new ones on the 4.7's
__________________ VISIT MY SITE (TheePlaymaker)
96 XJ, 4.0, auto, 4x4, HF Cat, 40 series, K&N, Accel, M/T, 199k miles!
Location: Hometown= Highland Michigan School= Lima Ohio
i know one ting i would check is the side panels of the bed, especially the ones without the fender flares they tend to rust out suddenly from the inside out, i made this mistake with my truck and now its completely rotted out
(only northern states of course, where they use salt on the roads in the winter)
__________________
2000 Dodge Dakota
4.7L V-8
3/4 Drop
paint, especially the green seems to be falling off just about every dakota i see of this vintage. I actually just shot a new coat of clear on my roof in an effort to slow the inevitable
__________________
1999 SLT dakota 5.2l 4x4
Airaid Cold air intake
Under drive pulley
Denso iriduim spark plugs
flowmaster 40 series
