Ok here's the deal. I need to chnge the shocks on the front of my truck. Problem is I haven't changes a set of shocks since I owned a '79 malibu and don't really remember the procedure. Anybody want to give me a quick run though of what I need to do?
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad. Click here to register for free!
1) Take tire off
2)Remove top nut
3)Remove bottom bolt
4)Install top nut
5)Push shock like a mother****er and have someone thread the bolt
6)Tighten nuts and bolts and make sure to torque the hell out of the bottom bolt. I had one come out on me while I was wheeling once.
7)Put tire back on.
Location: Southeastern CT (home), Middle of nowhere VT(school)
Its much easier if you jack the truck up under the lower control arm and remove the front tire. Then just removed the bolt on top and on the bottum and the old shock will come right out. And the new one will go in easily. Much easier than "Push the shock like a mother****er and have someone thread the bolt".
It's really easy especially if you jack up the truck under the lower control.
__________________
2001 Dakota sport 3.9 auto 2wd 135k - SOLD
2002 Dakota sport 4.7 5 speed, 4x4 112k and counting
See, tried doing mine that way, but it was really hard to get the right amount of lift from the jack. It may be more physical work to push it up, but I find trying to work with the jack was just more hassle than it was worth.
Work with the jack? It's not that difficult. You place the jack under the lower control arm and jack it up to take all the spring tension off the shock... Then just unbolt it and it comes right out nice and easy and goes back in just as easy.
__________________
I jsut drove the front of my truck onto some ramps without removing the tire.
