I have a 2004 dakota quad 4x4. I want to install a sirius antenna out the back brake light above the rear window. I need to know how to remove the headliner so I can run the wire up to the radio in the front. Any help ??
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad. Click here to register for free!
ive got a club cab and when i removed mine i know u have to remove the pillar trim near the windshield, which i believe came out with a 4mm hex key. you pretty much have to remove all trim that touches your headliner should either just pull off or you have to unscrew it like the seat belts, then there may be a couple of plastic pullout tabs near the rear window, and you have to take off your overhead console, which should just have one screw torwards the front of the console that you remove push forward, should move prolly bout an inch, then pull down
thats at least how we got it out on my truck hope this helps
Hey Josh Thanks alot for the info Im going to try. All this just to hide the sirius radio antenna lol
