1996 3.9 Fuel Injectors
Old 01-24-2010, 11:03 AM
756pro's Avatar
756pro
756pro is offline
Default 1996 3.9 Fuel Injectors
Bosch injector with the 4-hole disc fuel nozzle. are they any good? or should i go stock injector?
Old 01-24-2010, 11:50 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Crazy4x4RT is offline
By memory the stock fuel injectors only have 1 hole. The 4 hole will be better for atomization of the fuel. But on a stock engine especially on a V6 it is not needed. If you were to do a supercharger or turbo then it would help.
I say stick with stock style. Unless you are replacing yours anyways. And you get the same pressure rating injectors.
Quick Reply: 1996 3.9 Fuel Injectors
