1998 Dodge dakota, water in oil, heads and gaskets are fine.
Old 04-12-2010, 06:20 PM
Qaiphyx's Avatar
Qaiphyx
Qaiphyx is offline
Default 1998 Dodge dakota, water in oil, heads and gaskets are fine.
What could the problem be?
5.2L engine
Old 05-02-2010, 02:33 PM
Qaiphyx's Avatar
Qaiphyx
Qaiphyx is offline
bump to this question.
Old 05-02-2010, 02:38 PM
JDakota92's Avatar
JDakota92
JDakota92 is offline
There's only a few possibilities.
1. Head gasket(s)
2. Cracked head(s)
3. Cracked block
There's not a lot of ways for these two fluids to mix.
Old 05-02-2010, 02:44 PM
Qaiphyx's Avatar
Qaiphyx
Qaiphyx is offline
must be a crack block then, as I said in the title the heads and gaskets are fine, new actually.
Old 05-06-2010, 02:43 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Crazy4x4RT is offline
I will move this to the 2nd Generation Dakota Sub-Forum.
Old 05-06-2010, 06:35 PM
tamcnally's Avatar
tamcnally
tamcnally is offline
Location: Salisbury, Vermont (home) - Lima, Ohio (school)
Just saying the heads are new does not mean they are good. I recently rebuilt a C15 cat engine and they head that was delivered from cat was cracked. Also, this could be caused by head gaskets installed upside down. Or cross threaded head bolts or the heads could have been torqued incorrectly and that could have cracked them. Never overlook the little things while diagnosing, it'll come back to bite you.
Old 05-06-2010, 07:01 PM
alleymad99SLT's Avatar
alleymad99SLT
alleymad99SLT is offline
IMHO, I would start with the assumption that it is the head gaskets. You have a pretty serious problem and I would start with the cheapest potential issue. Whats the worst that happens if you pull of the heads and the gasket isn't wet? Your out a set of bolts and your time. But, you were going to take the new heads off if the block was cracked anyhow, so you really haven't lost anything...
Be optimistic.
Old 05-06-2010, 07:55 PM
984x4's Avatar
984x4
984x4 is offline
Pull the heads, have them magna-fluxed. This will tell you if the heads are indeed good.
If they checlk out good, then you have
1-bad head gaskets
2- cracked block (kinda unusual)
3- didn't have heads torqued properly, thus causing a leakage.
I'm betting the gaskets or heads.
Quick Reply: 1998 Dodge dakota, water in oil, heads and gaskets are fine.
