AX15 Transmission
#21
#23
Don’t go super cheap
Don’t go super cheap on http://www.car-part.com/ they have a rating system try and get one rated A and spend the extra money think $500 or $700
If you go to cheap you may end up with a garbage trans and waste your money and time
Be very careful these places will not refund most things you get from them you buy you keep you lose if not the correct trans.
#25
#26
let me rephrase this, my question is can i just eliminate using 1st gear and just start out in 2nd and baby the clutch without much wear on the clutch?
back to the subject found this ebay tranny
http://www.ebay.com/itm/AX-15-AX15-J...6e6ce8&vxp=mtr
and a clutch kit off of rockauto, would that be sufficient?
i apologize for sounding like a ******* but im pissed of the whole situation in general.
#27
YES just baby it
back to the subject found this ebay tranny I would not know but it is for a 4.0 engine and will be geared differently and may mount differently also.
YES just baby it
Also beware the AX-15 in a 2WD is different than a AX-15 in a 4X4 the way it shifts is my understanding.
#28
#29
