98 Dakota 2.5 won't start - DodgeForum.com
2nd Gen Dakota 1997 - 2004 Dakota's
Old 09-17-2012, 11:27 PM
jjbowden71
jjbowden71 is offline
Default 98 Dakota 2.5 won't start
Truck was parked for a while after my daughter in law blew the head gasket. Replaced the head gasket and got it running. Pulled it into the garage, put in new plugs, wires, distributor cap and rotor. Engine turns over but no spark. tried jumping spark from the plug wire to the block, nothing. tried from the coil, same thing, no spark. Connected obdII, can't get a connection. Ideas/suggestions please. Need to get it running for my grandson. Some jerk just totaled his car and the other guy didn't have insurance.
Old 09-17-2012, 11:43 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
Default Distributor Ignition Pickup
You may have offset the Distributor Ignition Pickup its just under the rotor you replaced pull off the cap and rotor its under that look at it for damage cut wires dirty connection plug.
If that is bad no spark will happen not sure how to test it.
looks like this
Just be careful if you need to replace it that year 1998 the 2.5 changed the connection from a round connection to a blade connection you need to get the correct one it could be one or the other.
Old 09-17-2012, 11:52 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
This is the newer blade connection
This is the old round connection one
The 1998 Dakota could be one or the other
Old 09-18-2012, 12:03 AM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
One other thing it just lifts out no screws nothing the cap keeps it on when you screw it down
Other things to think about a bad cap or rotor with the cheap China crap now switch back to the old stuff and see what happens
Old 09-18-2012, 11:13 AM
00daksport25
00daksport25 is offline
If you can't connect to the obd then it might be a pcm problem and not an ignition problem. Have you tried checking your wiring to the pcm to see if any of them are split or cut?
Posted from Dodgeforum.com App for Android
Old 09-18-2012, 11:27 AM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
00daksport25
I was thinking the same thing he may have leaned on the connections and popped one lose. I know with my 2.5 PCM its easy to do when in that area working on the cap and rotor.
00daksport25 I did replace my Distributor Ignition Pickup and it did make a difference she ran smoother for me.
Old 09-18-2012, 07:45 PM
jjbowden71
Thank, all the new things I put on are from China
Old 09-18-2012, 07:52 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
So its running now
Old 09-20-2012, 07:07 PM
jjbowden71
Not yet, have been working late everyday. May not be able to get to it until Saturday.
Old 09-22-2012, 12:54 PM
jjbowden71
Did you know that the coil on the 98 dodge has a fuse of it's own. I just figured that out after going through everything I knew to do when a truck doesn't have spark. I have had lots of trucks, but this is a first for me. I appreciate everyone's responses.
Related Topics
Thread
Forum
Replies
Last Post
dakotaff
Archived Classifieds
2
07-18-2015 09:44 AM
tooltime
1st Gen Dakota
8
07-11-2015 06:35 PM
dka
2nd Gen Dakota
4
07-10-2015 11:42 PM
shortlid
2nd Gen Dakota
1
07-09-2015 05:39 PM
90vnt
3rd Gen Dakota
1
07-07-2015 09:34 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
