Can i bypass the a/c compressor with a shorter belt ?
Old 10-04-2012, 11:11 AM
Schuey's Avatar
Schuey
Schuey is offline
yeah as in the diagram the compressor is upper left.. any ideas of belt part numbers or brackets ? my local ex dodge is pulling his hair out trying to find me parts since the daks bearing froze up today and engine wont even turn over or well does but with alot of binding and then sparks shoot out of compressor so truck being towed down to exdealer today..
im more then happy to pass on chrysler part numbers or any info since this is the closeth auto repair my roadside would tow me to for free .. #countrylivingsometimessucks
Schuey
Old 10-04-2012, 11:28 AM
dodgeramguy85's Avatar
dodgeramguy85
dodgeramguy85 is offline
Either call a parts store and ask for a bypass pulley. Or take the belt off and take it to a parts store they should be able to measure it and give you a idea of what belt you need. I would get 3 different sizes just so if one is a little tight/loose you can try a different one.
Old 10-04-2012, 01:44 PM
cummingetit's Avatar
cummingetit
cummingetit is offline
When i did my bypass on my 5.9 i took a ratchet for the tensioner and sat right in their parking lot until i had the right belt. I'm sure no one would say anything to you either as long as you weren't making a mess.
Posted from Dodgeforum.com App for Android
Old 10-04-2012, 01:48 PM
cummingetit
Btw i didn't get a bypass pulley, just removed the compressor and put on a shorter belt. On the 5.9 it cleared the compressor good enough to get home and take it off
Old 10-05-2012, 02:34 AM
magnethead's Avatar
magnethead
magnethead is offline
yea pretty sure with the 4.7 you'll need the bypass pulley without question.
In an emergency, I've been told to drill out a skateboard wheel and shove it in place of any pulley that needs bypassing. Not sure how well it works, supposedly they're self lubicating.
Old 07-21-2013, 12:02 PM
Brian in Tucson's Avatar
Brian in Tucson
Brian in Tucson is offline
Originally Posted by Schuey
on my 2003 4.7 ? ive spoken to the local ex dodge dealer he tells me i cant but im guessing thats just sales speak any ideas ?
I know it's an obvious and stupid question, but why don't you just get another compressor?
Old 05-13-2014, 03:10 AM
bluntrauma's Avatar
bluntrauma
bluntrauma is offline
On my 95 dodge dakota with the 3.9 I bypassed the a/c compressor with a 905k7 belt 905 being the length and k7 being the number of groves... it may work for 97-up
Old 06-22-2014, 10:17 AM
EricBing's Avatar
EricBing
EricBing is offline
well folks there isnt a 4.7 bypass available. 2000, 2001 yes...2002 Nope... at least i havent found one yet, if ya'll know where i can find hit me up Please, the noise is driving me crazy lol
Old 06-22-2014, 11:01 AM
MoparMan1991's Avatar
MoparMan1991
MoparMan1991 is offline
The 4.7 is the same engine regardless, why would the year matter?
Old 06-22-2014, 12:55 PM
EricBing's Avatar
EricBing
EricBing is offline
in 02 every dakota had AC and it was a different compressorm dont know for sure but didnt wanna chance it on special order of bypass pulley for an 01, so i removed compressor and installed a longer belt problem solved..routed belt different from a diagram on another post http://api.viglink.com/api/click?for...Forum.com&txt=..It worked wonderfully 83 3/8" belt
Quick Reply: Can i bypass the a/c compressor with a shorter belt ?
