Driver side Squib
Driver side Squib
Hello
My 2000 DD has the airbag light on I have taken it to the dealers and they said it is the clockspring so i changed that and it stayed on so i took it to my normal mechanic and they read the code and it said that driver side squib which means there could be a pinched wire or something and i have been looking around and some people have said its the clock spring and now when i hit my horn the wipers go. it has done this before and the place where i bought it said they fixed it and it went away for like a month or so now it is back any one have or had this problem and can give me some insite on it
thanks
thanks
The horns and windshield washer pump use the same ground on the RH front inner fender. Make sure it is clean and tight.
You could have a bad airbag assembly as well. If you paid the dealer to diagnose and fix it then take it back. It's not something you really want to be playing around with.
Good luck.
Good luck.
