Rear Drum Brake Problems - 97' Dakota 3.9L
Old 03-27-2014, 12:24 PM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
Dodge Forum Moderator
Measure the drum. It should be stamped on it somewhere too.
Old 03-27-2014, 12:33 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
Look in the glove box on the door it should tell you the size
I think looking at your Pic's they are the larger of the two
Here are my 9'' brakes http://s1076.photobucket.com/user/73.../Rear%20Brakes
Old 03-27-2014, 12:58 PM
tylan's Avatar
tylan
tylan is offline
Originally Posted by sxrsil3nt
I thought it was either 9" or 11".
Just by looking and judging by the year of your truck I'd say 9 inch.
Also, if you have 15 inch rims you have the 9 inch ones. (15 inch rims won't fit on 11" inch brakes).
And lastly, there should also be a sticker in your glovebox letting you know the size.
Yes I have 15 inch rims. I will try to find the sticker. thanks!
Old 03-27-2014, 01:07 PM
tylan's Avatar
tylan
tylan is offline
thanks! found the sticker, it's 9 inch!
Old 03-27-2014, 01:10 PM
sxrsil3nt's Avatar
sxrsil3nt
sxrsil3nt is offline
No problem.
Good luck!
Old 03-27-2014, 01:45 PM
tylan's Avatar
tylan
tylan is offline
Fantastic photos!
Right now I am just gathering parts for the rear brakes because I need to fix my power steering leaks first.
As for the parts, I believe I will need these:
Do I need any special tools? Thanks!
Old 03-27-2014, 04:15 PM
sxrsil3nt's Avatar
sxrsil3nt
No special tools needed. There is a spring tool for the brakes that you'll see online but a screw driver works just fine.
It may be worth it to invest in a flare wrench when trying to remove your brake lines from the wheel cylinder. It's extremely easy to round off the edges with a regular wrench.
Old 03-27-2014, 07:43 PM
magnethead's Avatar
magnethead
magnethead is offline
It's 9 and 10 97-00, 9 and 11 01-04 IIRC
Old 03-27-2014, 08:08 PM
sxrsil3nt's Avatar
sxrsil3nt
Thanks Magnet, didn't know that.
Old 03-27-2014, 09:40 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
Some info that may help always adjust the back brakes with the parking brake off just be sure it cant roll away on you put blocks under the wheels if a manual trans put it in first gear as a backup with the blocks.
Oh and don't over adjust or the back brakes will bind on you and be very very very hard to get the drums off.
Just go easy on the adjusting go in steps if not sure
Quick Reply: Rear Drum Brake Problems - 97' Dakota 3.9L
