Video: Changing Transmission Lubricant
Old 08-30-2014, 01:53 AM
cber's Avatar
cber
cber is offline
Default Video: Changing Transmission Lubricant
So after learning an expensive lesson (ended up buying 2 or 3 fluid changes for my transmission), I've recorded a YouTube video on how to flush the transmission lubricant in a manual transmission, and thought I'd share.
Old 08-30-2014, 02:33 AM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
This is for an AX-15 correct is that what you have?
Their is a better way to get the oil in an oil syringe sure it cost a bit of money but makes it easy to fill the trans.
Old 08-30-2014, 02:41 AM
cber's Avatar
cber
cber is offline
Image snipped
Yeah I bought that little hand pump thingy literally 5 minutes before recording the video, and it was a pain to use because little did I know before-hand there was no valves in the pump to make one side pull and one side send, it was basically just that little ball with a hose on either end, so I ended up squeezing it, then capping my thumb over one end to make it draw some fluid, and it just ended up being a huge pain in the butt.
Next time I'll probably just get one of those little syringes.
Old 08-30-2014, 03:03 AM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
Angry
On an AX-15 Before you drain any oil I would check your fill plug first they tend to be super hard to remove very thin plug so getting a socket or anything on that thin fill plug is a Pain in the @ss.
That's why you resort to taking off the shifter to fill the trans up because getting the fill plug off may not work then you are stuck with an empty transmission no oil.
The problem I finally figure out is they used a soft aluminum washer on the fill plug and aluminum is notoriously sticky find a replacement washer that's steel or brass or no washer at all then next time it will come off easy.
I looked everywhere online for a bigger head fill plug and you cant fined any they all have very thin heads.
Every wrench, socket or tool tends to slip off that F-ing plug like butter and the head gets mangled up bad.
I now have a nice new plug that I only lightly tightened up as its thin like the OEM plug what a PAIN.
Quick Reply: Video: Changing Transmission Lubricant
