01 4.7 Dakota Wiring Catastrophe
Old 03-26-2015, 09:44 PM
jassgraphix.com's Avatar
jassgraphix.com
jassgraphix.com is offline
Unhappy 01 4.7 Dakota Wiring Catastrophe
Never ever hook up your boat trailer or any trailer pigtail without a proper fuse inline. I decided to be that brilliant and do such and now I am paying the price. Truck has been out of commission for almost a year. What ever box is mounted under the dash with about 2 dozen wires coming in completely melted after the pigtail wires pinched under the trailer ball. Einstein! I went to the junkyard and found a used box and spliced it in. Everything seems to work properly all except the brake lights. I have changed the brake light switch, bulbs, twice. I have no clue what to do next. Should I look at the multifunction blinker switch? Is the box out of the junkyard bad? I have read on the net maybe the ABS sensor is bad? I am just clueless at this point on what to do or how to finish troubleshooting. I almost want to just install a universal brakelight switch and bypass all existing wires. If I had a clue on how to do that I would. Anybody that can help me troubleshoot this and get my truck fixed I will gladly mail you something off my site in exchange for your help.
#dakatohopeless
2001 Quad Cab 4.7
Old 03-26-2015, 11:14 PM
archemedes74's Avatar
archemedes74
archemedes74 is offline
have you checked the wiring going from the pigtail to the tail lights?
Old 03-27-2015, 06:13 PM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
Dodge Forum Moderator
The combination flasher works the stop/turn lights. The brake switch just provides an input to the combination flasher.
Is the CHMSL (3rd) brake light working? That is run directly off of the brake switch.
Quick Reply: 01 4.7 Dakota Wiring Catastrophe
