Identify this?
Identify this?
2003 quad cab with 4.7. Thought I had some road debris hanging from underside of truck, grabbed and pulled and it came right out. What I though was a random packing strap on closer inspection looks like a body grounding strap that was busted and hanging down. It was right under rear passenger door hanging down. I got under and I don't see where either end was fastened, anybody seen this or can verify there is one on their truck? Thanks!
On my (admittedly different generation!) 1988 Dakota, the bed end is in the very middle (right/left) of the bed, at the very front. The wires run to the right and left from there. I've not had to mess with the cab ends, but a close inspection should show where the grounding straps go.
Or, find the same generation same cab Dakota in the boneyard and pull the grounding straps off of it, to replace these.
RwP
RwP
