What in THE h*ll were they thinking?
I need help, guys. 01 dak V8 4x2. Took wheel assy apart to change ball joints. Top bolted in; no problems there. But the lowers, OMG! Was told I could grind heads off the rivets and punch them out. NOPE! Ground heads off and proceeded to try a punch to get them out. Then tried to drill out. Then air chisel and air hammer. THEY WILL NOT COME OUT! I'm stuck at this point. Any ideas to get them out?
When I replaced my ball joints I found it was a lot easier to start by drilling a 3/16" hole clean through the rivets. Then I drilled progressively larger holes in the rivets, changing to a larger drill bit about 5 or 6 times until I got up to a 7/16" bit. Once I drilled it that big the rivet body fell out on my garage floor. The rivets are made of fairly tough steel. Cobalt bits worked best for me. I broke a few steel bits before trying my cobalt set. Had to buy the 7/16" cobalt bit at Home Depot. Take your time, be patient and use good drill bits and it will come apart.
Jimmy
Jimmy
