Power Steering Connection Question
I recently replaced my power steering pump, as well as the rack and pinion. The gearbox seal failed, and the pump dumped fluid then the shaft seal failed.
After replacing everything, and flushing, I have a whine in my pump, and will sometimes loose power assist at low rpm (idle). The whine only occurs when I am off center with the steering.
Which power steering hose goes to which port on the rack (which is pressure and which is return).
I have a 99 Dakota 2WD with the 3.6L V6.
