ctm help
Old 08-28-2015, 12:29 AM
alrdif's Avatar
alrdif
alrdif is offline
Default ctm help
My Alarm sys on 2002 dakota wouldn't turn off. towed to dealer, reprog so alarm worked for a day. now no alarm, no lights, no automatic door lock. if I get a used CTM does the part # have to match exactly?
Old 08-28-2015, 08:15 AM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
Dodge Forum Moderator
Welcome to the forum Alrdif. I moved your post into a new thread.
The part numbers have to match. In addition, you'll lose the keyless entry function after changing the CTM - the FOB's won't work. A dealer can reprogram them.
Old 08-28-2015, 08:26 AM
jkeaton is offline
Dodge Forum Administrator
Now you need to merge this one with the one you created.
Old 08-28-2015, 01:58 PM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
That's what happens when you try to do things after being awake for 20+ hours.
