Distributor seal?
Trending Topics
I just replaced the PCV valve I checked the engine as my check gauges (Oil pressure) dropped every time i came to a stop I was 2 qts too low only 1.5K miles since the plenum was fixed and i did all my work on it.. no oil leaks around except that little little dampness there in that back side not sure if thats the back side leaking or dist. but i know i siliconed that bastard well so i really dont think its leaking.
Checked inside the belly pan and could see nice wet oil coming down from the PCV port so i know its sucking excessive oil in.. I had a different one than spec bc the one for our truck is plastic and was noisy as hell I got one from a former car quest (now advanced) and it seems to be working well with out excessive rattleing.. looking down there doesnt look like any leaks and no pooling so i think my seal as far as my intake is good.. I have a video from month ago as i was watching oil level go down if anyone cares to comment on it.
basically as you can see in this video thats what it looks like inside except the pooling there right under the pcv.
so well see if it doesnt help slow down oil consumption.
as far as the pressure idea yea my dad was thinking same thing.. you know on these air hats and most engines when under pressure even old carb one's you recall it does suck oil even with filter there i have seen little oil drip on the inside air hat that would be pulling air through the system.. I'm half tempted to put an open element oil filter there and capping off the system like they used to do on the old systems when they went open air filter..
Thoughts?
Thoughts?
