My 2000 Dakota truck the overdrive switch on the shifter is broken rather than replace the whole shift lever which looks like a pain in the ***. I'm just going to put a switch under the dash. Question is, is the switch a momentary switch or a constant on off switch. Push button. Or a flip switch.
Pretty easy to replace the shift lever and od button actually . Just remove shift collum covers remove pin that holds lever unplug wire harness and reverse the process
