03 Dakota Driver window Regulator
So I've had this issue in the past where the passenger window will only roll down when it feels like it. I can operate it from the driver side but the passenger side only works ocassionally. Yesterday, I rolled down the drivers window (from the driver side control) and heard a bunch of what sounded like plastic fall between the door. Today, I took off the door panel, unhooked the door lock and door handle levers, disconnected the electrical plug for the door switch, pulled off the plastic and put my hand between the door using the very small access holes that not very many people can stick their hands down and pulled up several pieces of white plastic that I assume have something to do with rolling down the window. Anybody know what part I might need or a place I can go to research what I need to fix...It doesn't look that difficult but I also don't want to get in over my head. Would this be the opportune time to replace the window switch which might in turn fix the passenger side window problem? Thanks
