Dakota Dash Guages Not Working
Old 09-24-2016, 04:08 PM
TJH 555's Avatar
TJH 555
TJH 555 is offline
Angry Dakota Dash Guages Not Working
Hi, I am in the UK and my dash gauges have all gone off! Occasionally they will all flick on for a second then go off again. Is there a common fault? Or an earth/connector which would cause this before I have to pull dash out?
I have not had this truck long and I did a 'check' with the computer and it comes up with codes 900/920/921/940/950 and 999!! Some of these might be old one's ?
Thank You, Tim
Old 09-24-2016, 05:09 PM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
Dodge Forum Moderator
Hi,
900 - CCD data bus is not operational
920 - The cluster not receiving a vehicle speed sensor signal from the PCM.
921 - The cluster not receiving a distance pulse message from the PCM.
940 - The cluster is not receiving an Airbag lamp-on message from the ACM.
950 - The cluster is not receiving an ABS lamp-on message from the CAB.
999 - An error has been discovered.
The CCD bus is the likely problem. Something can be shorting it out. What year is your Dakota?
I've moved your post to the proper forum.
Old 09-24-2016, 05:20 PM
TJH 555's Avatar
TJH 555
TJH 555 is offline
Hi Dan, This is a 1997 3.9 2wd. I had a 2000 4.7 4wd before for 8 years and it is the best truck I ever had. Tim.
Old 09-24-2016, 05:45 PM
TNtech's Avatar
TNtech
TNtech is offline
Site Moderator-Dodge Tech
Check the dash brackets where they attach to the body on both ends. They're behind the kick panels. One large bolt on each, make sure they're tight. If it's happening and it's the ONLY symptom, I would start going at grounds for sure.
Quick Reply: Dakota Dash Guages Not Working
