newbie needs help with auto trans ? '99 Dakota
Old 03-28-2017, 04:00 AM
650tr6hardtail's Avatar
650tr6hardtail
650tr6hardtail is offline
Default newbie needs help with auto trans ? '99 Dakota
Hello from Iowa
Just joined today. I'm old as dirt and twice as dusty with no computer skills and a bit of a Luddite as well. Let me know if I step on any toes. Have a 99 Dakota 318 4wd with a lunched 44re if i used the VIN decoder correctly. A neighbor has a 2000 Durango 4.7 V8 motor is stuck - run without coolant by his kid (who actually said "it quit leakin water so I figr'd it was ok"). I don't have the VIN but don't all the 4.7 use the (5)45RFE? Which brings me to my question, can I use the (5)45RFE from the '00 Durango in the '99 Dakota?
Thanks
Old 03-28-2017, 01:10 PM
magnethead's Avatar
magnethead
magnethead is offline
No, they are two completely different systems. 99 and 00 do not even use the same chassis or cab electrical or control systems.
Old 03-28-2017, 04:43 PM
bearclaw's Avatar
bearclaw
bearclaw is offline
Nope. 99 was the last year. If the Dakota was a 2000, you could swap.
Old 03-28-2017, 05:44 PM
magnethead's Avatar
magnethead
No, as even then the 545RFE does not bolt up or compute with a 318 engine/computer. 545 slushbox and the 4.7 is the only dakota/durango pairing that works.
Old 03-28-2017, 10:36 PM
bearclaw's Avatar
bearclaw
bearclaw is offline
You are right, I stand corrected.
Old 03-29-2017, 08:04 AM
650tr6hardtail
Gentlemen
Thank you for setting me straight on this. Glad I asked here BEFORE i handed over the $$ this time. Is there a sticky that would show me what would be workable donors? I tried to find one but got frustrated and went out side to yell at passing children " GET the hell off my lawn".
Thanks again, you saved me a bunch of hassle.
