DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Dakota > 2nd Gen Dakota
2nd Gen Dakota 1997 - 2004 Dakota's
Thread Tools Search this Thread
Old 11-03-2006, 02:42 PM
white97 white97 is offline
Default TPS Question
Does anyone know if the TPS is linked to the cruise control? My engine idle jumps around a couple hundred rpm sometimes and my cruise control doesn't hold as steady a speed as it use to. I am going to clean the IAC and test the TPS/replace if bad, I just wondered if these two issues might be related. I have also been checking for vacuum leaks - found none so far.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
97 dakota sport 4x4
std. cab, shrtbox
5.2L, 5spd man.
3.92 axle
trailer pkg.
H.D. cooling opt.
skid plates
22 gal. tank
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 11-03-2006, 02:45 PM
steve05ram360 steve05ram360 is offline
Site Moderator
Dodge Forum Moderator
Vehicle: 2005 Ram CTD 4x4, 2000 audi TTQ
Default RE: TPS Question
welcome to df...
yes, they are most likely related... the tps will get noisy and cause the torque converter to lock & un-lock. if this is what your seeing, swap it out and it should be good to go.
__________________
http://www.dodgeforum.com/m_1037052/tm.htm
http://s41.photobucket.com/albums/e266/sdoherma/
Old 11-03-2006, 02:48 PM
Thanks for the qwik response. Just to clarify- I have a manual Trans. no torque converter. Same diagnosis?
__________________
97 dakota sport 4x4
std. cab, shrtbox
5.2L, 5spd man.
3.92 axle
trailer pkg.
H.D. cooling opt.
skid plates
22 gal. tank
Old 11-03-2006, 07:59 PM
Site Moderator
yup, that would be the only way you'd see it.... cruise control
__________________
Old 11-04-2006, 12:56 AM
O.K. Update for ya. Cleaned IAC( sooty but no hard deposits) replaced TPS(jerky readings when working throttle) Checked intake plenum gasket-O.K.(replaced a year and a half ago) Engine still jumps up a hundred rpm or so when I push in the clutch to make a stop somtimes and then it drops to 500rpm and back up to maybe 700 or so before settling in around 600 rpm at idle. Tested IAT sensor a month ago- reads good - should I clean it? Could it be the O2 sensor? Doesn't really affect drivability but it makes me wonder and it probably hurts gas milage a bit.
__________________
97 dakota sport 4x4
std. cab, shrtbox
5.2L, 5spd man.
3.92 axle
trailer pkg.
H.D. cooling opt.
skid plates
22 gal. tank
Old 11-04-2006, 02:22 PM
kurbycar32 kurbycar32 is offline
my mustang used to do that when it had a vacuum leak. when you put in the clutch the motor has a sudden extreme drop in vacuum, then compensates
__________________
1999 SLT dakota 5.2l 4x4
Airaid Cold air intake
Under drive pulley
Denso iriduim spark plugs
flowmaster 40 series
Pioneer deck/changer sirius radio
2X 10" subs 400w fosgate amp
Kicker component speakers 600w jensen amp
Old 11-04-2006, 03:33 PM
Site Moderator
reset the PCM before you do anything else... let the comp re-learn the motor with the clean IAC & new TPS. I'll be it'll be fine. but if you do want some maintanance to do.. you can yank the o2 sensors & clean them with CRC electronic parts cleaner from the auto parts store. spray into the holes where the exhaust stream enters the sensor. spray alot. spray all the holes. let it dry & then re-install. o2's fail because they cannot get enough exhaust flow to measure for the air. clean it every 20~30k and they will last longer and perform better.
__________________
Old 11-04-2006, 04:43 PM
I was wondering this morning if I needed to reset the PCM. Now I know. Thanks a bunch for the help! This forum is great!
__________________
97 dakota sport 4x4
std. cab, shrtbox
5.2L, 5spd man.
3.92 axle
trailer pkg.
H.D. cooling opt.
skid plates
22 gal. tank
Old 11-04-2006, 05:32 PM
Site Moderator
when you reset the pcm, it re-learns everything. including the new tps you installed. if you dont, it'll still take a couple of hundred miles to relearn the new stuff but may act funny depending on what you replaced.
__________________
Tags
audi, radio, search, tps, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
