DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Dakota > 2nd Gen Dakota
2nd Gen Dakota 1997 - 2004 Dakota's
Thread Tools Search this Thread
Old 11-03-2006, 08:42 PM
tntitans21399 tntitans21399 is offline
Vehicle: 2003 Dodge Dakota Quad Cab 2wd V6
Send a message via AIM to tntitans21399 Send a message via Yahoo to tntitans21399
Default Noise from the rearend
I have recently noticed that my 2003 Dodge Dakota Quad Cab 3.9L V6 with 2wd has been making a noise coming from the rearend. I plan on going by and buying a haynes book to see if can help me find out what it is. The truck runs great and tows great without promblems. It is just when I turn sharpe I can hear a noise (like a grinding feel) coming from the rear end. I lifted the truck off the ground and got under the vechile and was able to locate that it is coming from the front part of the rear end. So I know it's not the rain gear or pinion, but it most be some part near the front of the rear end. I don't know if it is a part that maybe got worned down a little and needs to be replaced but not right away or if it is something needs to be replaced right away before more damage. I know about engines, but not alot about rear ends. Has anyone had this promblem? I know enough that I know that you would have to take the rain gear and pinion out to get the part making the noise. So I don't think it is something I can do, I might need to take it in. But If I can find the part I can buy a a better one at a better price then buying cheap expensive part from them.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
K&N Short Ram Air Intake with Heat Shield
Dual Exhaust with Flowmaster Dana 40 muffler with Stainless Steel Tips
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 12-06-2006, 11:49 PM
boats001 boats001 is offline
Junior Member
Default RE: Noise from the rearend
Hey do you have a posi trac rear end. Does the noise get louder when you make a turn. If this is the case you may have a broken clutch plate inside the posi trac. I just replaced mine on my 2001 dakota if you need any help or places for parts look me up
__________________
2001 dakota 4x4 quad cab
4.7 dual exhaust
mostly stock
Old 04-10-2007, 01:17 PM
I went and had the fluid changed to see if that might be it. It doesn't make the noise when turning, but now I have noticed when I am slowing done I can hear a small noise, that you really have to listen for, mainly becausee the dual exhaust. I was going to jack it up and put it in neutral and move the tires and drive shaft to see if I can tell where the noise might be coming from. I don't think it has anything to do with the r. gear & pinion, but maybe more of the front of the diff. Would it still do those things if it is the broken cluth plate? And I can do some light maintance (replacing brakes, rotors, water pump, starter, etc...) so I was wondering how hard it would be to fix. SomethingI can do, or is something just to leave with the pros? Any help is great.
__________________
Old 04-10-2007, 03:06 PM
Rakaric's Avatar
Rakaric Rakaric is offline
2000 Dodge Dakota
Vehicle: Dakota 4x4 4.7L V8
Send a message via AIM to Rakaric Send a message via Yahoo to Rakaric
Can you desribe this noise a bit more? From experience I had a squeak coming from the rear as I slowed down. I took it to a shop for an inspection and they told me I had worn U-joints. The squeak I had would squeak all the time, but only at a certain point of rotation. I'm not sure if this situation refers to you. I guess if you can somehow lift the rear end and have the engine running, and push the gas a little but while it's in gear and see if that is where the noise is coming from.
__________________
Old 04-10-2007, 03:21 PM
lone_wolfin lone_wolfin is offline
i occasionally have a noise that comes from my rear end also....usually after eating pork (&/or) beans[sm=smiley36.gif]
Serious though...I used to work for a GM dealership (i did all their rear axles repairs).
If it is coming from the front part of the center of the rear axle, it would most likely be the front Pinion Bearing.
The axles, center section, and pinion (rear axle input shaft)would all have to come out.
Then the front pinion seal removed to get to the front bearing.
Then the front brg race should be replaced, and you might as well do the other pinion brg and race while you are there......
If it was me, i would probably just replace all the brgs, races, and seals while you have it apart.
Inspect the axle shafts for scoring/pitting where the bearing rides.
Old 04-10-2007, 03:35 PM
The noise I get I only get when I'm slowing down, not when I'm taking off. It's not very loud, hardly noticable and doesn't change with speed. I don't know how to describe it, it is kind of like when your engine whins downs when your going down hill. I know it's not the engine, but that kind thing. I guess it's when the rear end is slowing down.
__________________
Tags
2001, 2003, 95, axle, bearing, caravan, dakota, differential, dodge, end, front, rear, rearend, recalls, seal, squeak, squeek
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
