Go Back   DodgeForum.com > Dodge Trucks > Dodge Dakota > 2nd Gen Dakota
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Parts Search Today's Posts Mark Forums Read Used CarsGarageVendors TSB & Recalls
Welcome to DodgeForum.com
2nd Gen Dakota 1997 - 2004 Dakota's
Thread Tools Search this Thread
Old 02-14-2007, 01:29 AM
BeachCruiser BeachCruiser is offline
Garage is empty, add now
Default Oxygen Sensor Simulator
I've got a custom exhuast on my 97 and tore out the cat. I've got the check engine light on, but the 3.9 definatley seems to be running too rich. Are there any oxygen sensor simulators that do not require actually screwing in the sensor cause I didn't put a hole in my pipe for it and dont feel like doing it unless i have too. Thanks
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
1997 Dodge Dakota Sport V6 5 speed
Old 02-16-2007, 04:23 PM
imnothot02 imnothot02 is offline
Send a message via AIM to imnothot02
Default RE: Oxygen Sensor Simulator
Not that Ive seen or heard of... buy a new cat and put back in your O2 sensors...proaly would be cheaper than all the gas...
__________________
---Travis---
2002 Chevy Trailblazer LT 4.2
1996 Subaru SVX LSi AWD 3.3 L Flat 6 (Highway car)
1987 Grand Am 2.5 L Inline(Just keeps going and going...)
Can't forget the work van 04 3500 EXPRESS lol
Old 02-17-2007, 02:38 AM
dodgedakota98luver dodgedakota98luver is offline
mine doesnt actually screw in but you have to wire it into the wires on your preexisting o2 sensor. the heating element cant be by passed on your o2. however your secondary o2 sensor has nothing to do with running rich. it just tells your computer if your cat is bad or not
__________________
1998 Dakota Sport 4x4
Regular Cab Short Bed
5.2 V8 5 speed Manual
31x10.50 Federal Couragia M/T
Old 02-20-2007, 02:37 PM
yellowjacket99 yellowjacket99 is offline
I got mine from Jeg's, and it just plugs into the harness side pigtail. So you wouldn't have to put a hole in your pipe with that one.
__________________
2002 Dakota Sport 4x4 quad cab 4.7
Old 02-20-2007, 02:58 PM
DakotaStone DakotaStone is offline
Vehicle: 2007 Dodge Charger SXT
Send a message via Yahoo to DakotaStone
Does the OSS improve performance? I've been curious, and I've heard that it does, butI haven't heard enough to make an educated decision,and I know Fastman.com sells it.
__________________
Performance Mods: Big Bully Intake; R/T Exhaust; JDM Headlights; SRT Sways; Tinted Windows; Boston Accoustic Speakers and 10" sub, Crunch 500 watt power amp; KW V1 Suspension/Coilovers; Predator Tune; Fog Lights; 71mm TB and lower intake; HoneyComb grille; soon to be added JBA Headers.
Old 02-20-2007, 03:09 PM
Can't say for sure, I didn't really notice anything. I wouldn't think so cause as mentioned it basicallyjust tells the computer the cat is good and eliminates the cel. Getting rid of the cat or going to a hi-flow one might help performance, but I don't think the OSS alone will.
__________________
Old 02-20-2007, 04:19 PM
virused virused is offline
Send a message via AIM to virused
It will do nothing for performance. It will simply get rid of the check engine light associated with a bad cat.
__________________
Chris
MODerator
99 Dodge Dakota, 56 Ford F100, 06 Honda RC51
Old 02-21-2007, 04:25 AM
horatio102 horatio102 is offline
Vehicle: 98 QCSB 2wd 12-valve
If you're putting a simulator in for the pre-cat O2, you're going to mess up your A/F ratio since that one tells the ECU if it's running rich or lean. The after-cat O2 only tells the ECU if the cat is running properly.
__________________
98 12-valve QCSB 2wd
Old 02-29-2008, 12:51 PM
Ethica19 Ethica19 is offline
my high outputconverter keeps making my oxygen sensor throw a code more and more constantly now. If I get a simulator, will I only need one for the post converter?
__________________
99 Dodge Dakota Ext 3.9, 4WD
Rancho shocks, K&N filter, Holley throttle body
Ecilpse 600 watt Amp, Bazooka Subs, DB Digital Capacitor, Monster wire, Borla Exhaust System, Magnaflow catalytic converter, Royal Purple fluids
Old 02-29-2008, 01:20 PM
Loud Pedal's Avatar
Loud Pedal Loud Pedal is offline
The Total Package
2000 Dodge Dakota
Vehicle: caddi
Send a message via AIM to Loud Pedal Send a message via MSN to Loud Pedal
i took the cat off mine and the engine lite come on too i bought a special pipe that angles the sensor pointing twords the back of the truck adn the sensor is sunken back a lil bit and the check engine lite is off now i think as long as the sensor isnt in the line of the exhaust it should be fine mine has 175,000 on it soo i need it tuned(burns rich too)
__________________
-01 Dakota SLT extended cab- mods: 3" drop, HO cams, intake, 4:10's, built trans w/shift kit
Tags
97, dakota, dodge, o2, oxygen, sensor, simulator
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
© Internet Brands, Inc.
Contact Details & Emails
Search Engine Friendly URLs by vBSEO 3.5.2
