2nd Gen Durango 2004 - 2009
Unstable front suspension over bumps
Old 03-20-2009, 03:52 PM
brainpa's Avatar
brainpa
brainpa is offline
Default Unstable front suspension over bumps
Hey all, I have a 07 4.7 Durango limited. Love the car except for one problem.
At speed, whenever I go over a bump, say a RR crossing, the front end becomes briefly VERY unstable; it feel like the front tires actually become disconnected from the road. After a sec it settles down, but I gotta tell you, it is not a good feeling when control is lost.
My questions are these:
A) Have you noticed this as well, and
B) Any fixes for this?
My thought is to replace the front struts with a more agressive type, to keep the front tires planted.
Whaddya all think?
Thanks
Old 03-22-2009, 08:55 PM
steemer14's Avatar
steemer14
steemer14 is offline
Default Squirrly
Have you checked ball joints and control arms? They could make a larger SUV really squirrly over some good size bumps
Old 03-22-2009, 09:51 PM
IndyDurango's Avatar
IndyDurango
IndyDurango is offline
My guess is your struts are simply bad/old/in need of replacement. Get something better than stock and go from there.
IndyDurango
Old 03-23-2009, 03:07 PM
vrunner's Avatar
vrunner
vrunner is offline
I have an 07 Limited too and have the same issues since the truck was new. I believe, setting aside the dealer B.S. it has to do with the 20" low profile wheels which since you have a limited I assume you have. Not enough meat between the road and the rims. I had an 05 before this one and it had the 17" rims with goodyear wrangler tires, no hop over bumps. So if it really bothers you get a set of standard rims and tires, it will help the problem.
Old 03-23-2009, 08:21 PM
1969CoronetR/T's Avatar
1969CoronetR/T
1969CoronetR/T is offline
vaffanculo
Dodge Forum Moderator
I have a 2007 LTD. with 20" wheels and this does not happen to me and I drive 35 + MPH over train tracks twice a day. I did have the tie end rods break twice and did not even notice a difference. I would suggest that IndyDurango is correct and the low profile tires are not to blame,
FF
Old 03-23-2009, 08:44 PM
IndyDurango
Thanks fascistfaction.
Speaking from experience, rear end hop on a Gen1 AWD D is easily solved by quality replacement rear shocks. Seems logical that would fix it on the Gen2 front or rear too.
IndyD
Old 03-29-2009, 09:23 AM
04Hermi's Avatar
04Hermi
04Hermi is offline
I am with you, personally I am going buy some bilstiens and see if it improves
Old 03-30-2009, 10:01 PM
IndyDurango
Bils solved my rear end hop.
IndyD
Old 04-08-2009, 06:16 AM
Czechman's Avatar
Czechman
Czechman is offline
I had a similar problem with my Jeep and it turned out to be the Steering Stabilizer. Not sure if your truck has one but my symptoms included if I hit a bump on a curve the steering wheel would shimmy.
Just a thought... good luck.
Quick Reply: Unstable front suspension over bumps
