what is 4 lock? - DodgeForum.com
2nd Gen Durango 2004 - 2009
what is 4 lock?
Old 04-11-2009, 08:38 PM
freddybeach
freddybeach is offline
Default what is 4 lock?
I just baught a 2004 durango slt. I noticed it only has awd and 4 lock. It does not have the 4 low option. Does this mean I am going to get stuck? I don't really go offroad much. Thanks I hope I didn't waste my money.
Old 04-12-2009, 01:25 PM
1969CoronetR/T's Avatar
1969CoronetR/T
1969CoronetR/T is offline
vaffanculo
Dodge Forum Moderator
If you do not go off roading or tow heavy loads in the snow or sand you will not need 4low. I only put mine in 4lock a cople times a year in the winter. I think 4lock is for if you get stuck while towing a heavy load,
FF
Old 04-12-2009, 09:12 PM
IndyDurango's Avatar
IndyDurango
IndyDurango is offline
The sky isn't falling.
Does every 2 wheel drive, every Hyundai, Honda, Mustang, Neon, etc get stuck? Of course not. Neither will you and you have a much better system than they do
Trust the AWD as it is better than 95%+ of every other vehicle out there.
IndyDurango
Old 04-12-2009, 10:18 PM
freddybeach
Default Thanks!But!
Thanks I agree. I am just a little confused about the 4 lock and can't seem to figure it out. I do go offroad once and awhile. I go through mud and water sometimes too. Will the AWD work and if not does the 4lock have any pull? Is 4lock really 4 wheel drive? I only ask because as far as Suv's go and trucks this is my first. Thanks for any information. Love the truck so far only had it 5 days.
Old 04-16-2009, 11:46 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
AWD moves power from the wheels that slip to wheels that grip. This means it's great on road and some slippery conditions. Power can transfer all to the front, the back, or 1 front and 1 back.
But if you need added traction then lock that baby down so that at least one wheel on both front and rear are gripping.
Old 04-17-2009, 12:57 AM
95_318SLT's Avatar
95_318SLT
95_318SLT is offline
The difference between AWD and 4x4 is AWD has a limited slip differential between the front and rear axles and 4x4 locks the front and rear axles together.
When you go around a turn on dry pavement (a high traction surface), all 4 wheels take a different path around the turn and therefore spin at different rates. The differentials that are on your front and rear axles allow the right and left wheels on each axle to travel at different rates, but when the front and rear axles are locked together (4x4), one front and one rear wheel is forced to spin at the same rate. This causes driveline windup and will break either axles, driveshafts, gears, etc, or will skid the tires causing excessive wear. AWD solves this by allowing a limited slip between the 2 axles so they can spin at different rates. This still allows all 4 wheels to be under power as needed, but won't cause driveline windup. In a limited slip setup, more of the power goes to the faster spinning wheel (the outside wheel in a turn, or the low traction wheel on a slipery surface), but not all the power like in an open differential system. Limited slip is typically good up to about a 60-40 split in power when one wheel is required to spin faster.
So to answer your question, AWD is a full time system that lets you give power to all 4 wheels as needed, but has a certain amount of slip between axles, and can only do 60-40 at best (usually no worse than 70-30 though) in low traction conditions and 4lock is a 4x4 that gives you that extra bit of traction when needed by locking the axles and giving you a 50-50 split.
I hope that isn't confusing without diagrams to show whats going on.
Related Topics
Thread
Forum
Replies
Last Post
evilemokid94
2nd Gen Ram Tech
22
02-29-2016 09:45 AM
mcweaver
4th Gen Ram Tech
4
09-30-2015 05:08 PM
fenderonly
2nd Gen Ram Tech
6
09-28-2015 03:25 PM
podfish
1st Gen Dakota
0
09-27-2015 10:07 PM
BAMF224
3rd Gen Ram Tech
3
09-27-2015 12:01 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
