2nd Gen Durango 2004 - 2009
air conditioner problems
Old 10-19-2014, 08:12 AM
Durango marty's Avatar
Durango marty
Durango marty is offline
this might sound crazy man but check you fan behind the radiator i had an electric fan go out and it caused the same thing. If you turn your a/c on the fan should also kick on if not your fan motor may have failed.
Old 10-21-2014, 06:49 PM
MoparMan1991's Avatar
MoparMan1991
MoparMan1991 is offline
I don't feel like going through the posts to see, but could it be going off on high pressure?
Old 10-23-2014, 09:36 AM
bald347's Avatar
bald347
bald347 is offline
The fan is working and the mechanic even added an additional fan which might have helped a little. I'm not sure about the high pressure thing. But the compressor seems to be working as in its not cutting off. The vent temp just starts to rise rapidly when I stop even at a red light. Its better now because I'm in south Alabama around Mobile and we have been having mornings in the 50-60 degree range and highs in the 70s which obviously have an impact on the air conditioner. Thanks for the replies so far.
Old 10-24-2014, 11:47 AM
azcromntic's Avatar
azcromntic
azcromntic is offline
The compressor not cutting off is an indicator that you do not have enough refridgerant (like I mentioned already) or a sensor is not reading correctly, or both. Charge the system at 2000 rpm, add some leak detector dye, and recheck the temp and pressure sensors. Then use it for a while and check to see if the dye has leaked out anywhere.
Old 12-14-2014, 12:57 AM
azcromntic's Avatar
azcromntic
Also something I did not know. Safecar.com lists a TSB Service Bulletin No.: 2401605 4.7L IMPROVED A/C PERFORMANCE. *SC
I'll have to reread your posts as I do not remember if you said you have the 4.7 or not.
Quick Reply: air conditioner problems
