17vin.com for option codes
FYI,
17vin.com will list every option code for a particular VIN and a brief explanation of each. Maybe a good alternative to a build sheet.
EXAMPLE of a D I'm looking at:
Home> chrysler>
Decode Vin
DecodingSales CodesGo to Catalog
*JJ Leather Trimmed Bucket Seats
-D5 Med Slate Gray
0A7 FAM: TJ TRACK PLAN: 97BUXMRKTS MODEL YR:
135 Zone 35-Washington
1AA U.S. Dealer Retail
28J Customer Preferred Package 28J
2TJ Customer Preferred Package 2TJ
3XL "No Charge" Rear Seat Video System
4VL In-System-Vehilce-Locate Tracking
4X7 Virginia Chapter-90 Recovery
594 Vehicle Order Tracking
5I4 Four Wheel Drive (4WD)/(4X4)
5ZX HB-Vehicle Family
647 Virginia State Code
6US Label - U.S. Specifications
947 Virginia State Code
*** 5.7L Eng(EZB)/5Spd A/T 545RFE(DGQ)
ADJ Heavy Duty Service Group
ADL Skid Plate Group
AFH Interior Convenience Group
AHC Trailer Tow Group
APA Monotone Paint
BAB 160 Amp Alternator
BCQ 750 Amp Maintenance Free Battery
BCS Run Down Protection Battery
BNB Electronic Stability Program
BRT Anti-Lock 4-Wheel Disc Brakes
CAD High Back Bucket Seats
CBZ Prem Vinyl Door Trim w/Map Pocket
CFG 4th Rear Bench 4 Passenger Seat
CG3 Advanced Multistage Front Air Bags**
CGL 2nd Row 40/20/40 Reclining Seat
CKA Carpets - Floor and Cargo Area
CKR Cargo Net
CKT Cargo Tie Down Loops
CLX Luxury Front & Rear Floor Mats
CSR Passenger Assist Handles
CUC Floor Console
CUN Overhead Console
CUR Rear Compartment Storage Tray
DGE All 5-Speed Automatic Transmissions
DGQ 5-Spd Automatic 5-45RFE Transmission
DHA Lock-Up Torque Converter
DHU Elec Shift-on-the-Fly,F/Time T/Case
DJD 205MM Front Axle
DMD 3.55 Axle Ratio
DRA Corporate 8.25 Rear Axle
EZB 5.7L Hemi Multi Displacement Engine
GAP Laminated Door Glass
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEG Deep Tint Sunscreen Glass
GFA Rear Window Defroster
GNC Sun Visors w/Illum Vanity Mirrors
GNT Rear View Auto Dim Mirror
GNZ Driver Auto Dim Exterior Mirror
GUN Power 6X9 Multi-Func Mirrors, F/Away
GWA Power Sunroof
GXR Keyless Entry
GXX Sentry Key Theft Deterrent System
HAB Air Conditioning w/Auto Temp Control
HBB Rear Air Conditioning w/Heater
JA2 Instrument Cluster w/Tach
JAC Premium Instrument Panel
JBM Instr. Panel Satin Silver Bezel
JCB 120 MPH Primary Speedometer
JHA Var Intermittent Windshield Wipers
JHD Rear Var Intermittent Wiper/Washer
JJB Dual Note Electric Horns
JJJ 12V Auxiliary Power Outlet
JJM Rear Power Outlet
JKP 12V Auxiliary Power Outlet
JPB Power Locks
JPD Power Windows, Driver One-Touch
JPM Heated Front Seats
JPP Power Frt 8-Way w/Drvr Memory Seats
JRC Power Liftgate
K2W STRIPE/BADGE/MOLDING/COLOR
LAC Illuminated Entry
LAF Key in Ign/Seat Belt Warning Buzzer
LAJ Headlamps On Warning Chimes
LAL Low Washer Fluid Warning Signal
LAM Door Ajar Warning Lamp
LAN Decklid/Liftgate Ajar Warning Lamp
LBC Glove Box Lamp
LBF Console Flood Lamp
LCE Rear Courtesy/Reading Lamps
LDG Liftgate Flood Lamps
LEM Exterior Mirrors w/Memory
LEZ Radio/Drvr Seat/Mirrors/HVAC Memory
LMB Halogen Headlamps
LMG Automatic Headlamps
LNJ Fog Lamps
LPS CHMSL Lamp
LSA Security Alarm
MDA Front License Plate Bracket
MFM Black/Bright Grille
MGA Ram's Head Badge
MHA Black Windshield Moldings
ML9 Body Color Rear Fascia
MLH Body Color Front Fascia
MNP Bright License Plate Brow
MVA Limited Badge
MW5 Hemi Badge
MWG Roof Rack
MWH Rear Wheelhouse Liners
MZJ Durango Bright Badge
NAS 50 State Emissions
NBE Federal Tier 2, Bin 8A Emissions
NBK EVAP Control System
NFJ 27 Gallon Fuel Tank
NHB Auxiliary Transmission Oil Cooler
NHF Power Steering Cooler
NHJ Exterior Mirrors w/Heating Element
NHM Speed Control
NHN Electronically Controlled Throttle
NMC Heavy Duty Engine Cooling
NZD Next Generation Engine Controller
PW7 Bright White Clear Coat
QW7 Bright White Clear Coat
RAQ AM/FM CD 6-Disc MP3 Radio
RCX 8 Infinity Speakers w/Subwoofer
RD6 368 Watt Amplifier
RDD Fixed Long Mast Antenna
RDZ Steering Wheel Mounted Audio Ctrls
RSA Sirius Satellite Radio
SBA Power Rack and Pinion Steering
SCG Leather Wrapped Steering Wheel
SDB Heavy Duty Suspension
SFB Front Heavy Duty Shock Absorbers
SGB Rear Heavy Duty Shock Absorbers
SHC Front and Rear Stabilizer Bars
SUA Tilt Steering Column
TBB Full Size Spare Tire
TBM Tire Carrier Winch
TP5 P265/60R18 BSW On/Off Road Tires
TZA Goodyear Brand Tires
WF1 17" Steel Spare Wheel
WPB 18X8.0 Aluminum Wheels
X95 Call SIRIUS to activate@888-539-7474
X97 1-Year Service Provided by SIRIUS
XAM Power Adjustable Pedals w/Memory
XBN Tip Start
XCA Occupant Classification System
XDX Scissor Type Jack
XEA Tow Hooks
XEE Fuel Tank Skid Plate Shield
XEF Transfer Case Skid Plate Shield
XF2 7 and 4 Pin Wiring Harness
XFH Hitch - Class IV Receiver
XGD Universal Garage Door Opener
XGQ Synthetic Rear Axle Lube
XRV Rear Seat Video System
XSL Brake/Park Interlock
YAA Build To U S Market Specifications
YHU 3.2 Additional Gallons of Gas
Z5C GVW/Payload Rating - 2000
ZAA Spring - Left Front
ZAS Spring - Left Rear
ZNA Spring - Right Front
ZNS Spring - Right Rear
Home> chrysler>
Decode Vin
-D5 Med Slate Gray
APA Monotone Paint
CKR Cargo Net
CUC Floor Console
DMD 3.55 Axle Ratio
GWA Power Sunroof
GXR Keyless Entry
JPB Power Locks
JRC Power Liftgate
LBC Glove Box Lamp
LNJ Fog Lamps
LPS CHMSL Lamp
LSA Security Alarm
MVA Limited Badge
MW5 Hemi Badge
MWG Roof Rack
NHM Speed Control
XBN Tip Start
XEA Tow Hooks
