05 Durango noise in front
When I first got this D it made a noise when trying to get into my garage going up a slope. I posted something and got a replied not to worry about it as it was probably the traction control. That was at 77,000 km. Recently I was at my neighbours and had to climb a muddy hill, there was terrible noises coming from both sides, sounded like the traction control engaging + disengaging. I tried shutting off the traction control but it didn't improve. I barely made it up the hill. After that there it a rubbing type noise coming from the drivers front that comes and goes. Today when I came back from fishing with my boat, when I hit a bump it made the noise like when you loose traction. I pressed the button to disengage the traction control but it made no difference. I don't know how to start to troubleshoot this. Please advise. BTW, it has 102,000 km on it now.
There isn't much anyone can do for noises in text form. If you have some way to record it, you will likely get some replies. Traction Control/ABS DOES feel terrible. Especially on a 4WD truck. Then your noise COULD be from a problem with the transfer case or some differential parts being worn.
