Top Speed ?
RE: Top Speed ?
Durango can reach 146 mph i tried it it is crazy
You have to pull one fuse
Near the driver side fuse box
there is a fuse for the ABS second column third or fourth row it is for the ABS
The only problem you have you wont have ABS and the Speedometer will stop. After reach 110 miles it will engage in fourth gear you shift the lever to second gear and it wil go back to third gear and go all the way down to 5900 rpm reach the speed of 146 mph
RE: Top Speed ?
John:
That is some weird secret spy manuevring to go through, and no offense but I hope no one is crazy enough to try it.
Besides the fact that the Durangos tires are only speed rated to 118mph, I would hate to see the mess and carnage that would ensue if you had to stop or make an evasive manuver at those speeds in a Durango.
The likelyhood that the driver of any Durango going that speed would survive a crash would not be a bet that I would take.
don
don
RE: Top Speed ?
ORIGINAL: n8ech
John:
don
John:
don
PS also some damage to the upholsery on the drivers seat.
Trending Topics
RE: Top Speed ?
My neighbor has an 04 hemi durango with ported heads,headers,dual exhaust,cam,ecu reflash,etc.He had the rev limiter raised, shift points raised, more agressive spark adv, top speed limiter raised,etc.The durango started swaying back and forth dangerously at 125-127mph! I don't see how anyone could get it any faster using a stock setup.
