DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Intrepid > 2nd Gen Intrepid
Thread Tools Search this Thread
Old 05-14-2009, 12:15 PM
kurts2 kurts2 is offline
Yes, change it first. The PCM can NOT sense fuel pressure status. If the pressure is low, it can fool the computer into thinking there is a misfire because the detection is done by the O2 sensors. That’s way an exhaust leak can also cause a false misfire.
The light itself can’t shut off the engine, only a malfunction (that the PCM is monitoring) can ;-) All kidding aside, I believe your “misfire” is erroneous because in your first post you said there were no misfire symptoms but seems to come on at aprox 3K RPM.
Fuel pressure is one of those things that can stall out your engine so start with the easiest…a fuel filter change. It may be a bad fuel pressure regulator or vacuum leak, but because you have no tools etc, this is a quick easy try.
I mentioned the MAP sensor only because it may be a coincidence and you actually have two unrelated malfunctions. It is an easy test if it is malfunctioning so I passed it on so we can eliminate it as a suspect (I have had several go out). The MAP is involved with engine timing and could cause a misfire but it would be a real misfire that you can feel.
That being said, are you sure there is no misfire present? Can you find a friend who knows what one feels like and have it confirmed? Otherwise we may be heading down the wrong rabbit trail.
Kurt
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 05-14-2009, 11:36 PM
jebs23 jebs23 is offline
Vehicle: 99' Intrepid 2.7 Auto
I am pretty sure its not an actual misfire because it never skips, putters, or bogs down; only when it randomly shuts of does it "putter" briefly. I will definitely tackle the fuel filter this weekend then, shouldn't be too hard. I am beginning to understand that A LOT of different things can trip this code, :-/ thanks for the guidance.
Ill let you know how it goes
Tyler
Old 05-17-2009, 06:13 PM
....Just another pattern i found when my car shuts off on me.. the past three times it has done it, its been very wet out, raining, or i go through a puddle THEN the car cuts out on me (happened again). I had the car running in my driveway and was spraying different spots of the engine with the hose and got the engine to cut out. so i know now that it is in fact "water" related... HELP?
Old 05-19-2009, 11:04 AM
It could be an electrical or vacuum problem. Any specific area you noticed?
Old 05-19-2009, 02:44 PM
Actually yes,(passenger side) i am pretty sure that i now know what my problem is. With the random shut offs and the misfire code...i believe it is my crankshaft position sensor that's bad...im going to replace it and see what happens..
thanks
Tags
02, 27, 99, avenger, chamge, check, dodge, engine, false, fuel, intrepid, light, misfire, random, regulator
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
