DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Intrepid > 2nd Gen Intrepid
Thread Tools Search this Thread
Old 09-27-2009, 06:02 PM
leona leona is offline
Default 2000 intrepid blowing fuse
2000 dodge intrepid blowing brake fuses ,no brake lights? worked one day gone the next nothing! Changed the brake switch at the brake pedal then relised the fuses were blowing!? whay how what where HELP? No bares wires shorting out that I can visually see checked all areas posiible ? Any suggestions,does anyone know if there is a break relay or sensor in a intrepid? thanks for the help and suggestions in advance!
leona
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 09-27-2009, 06:16 PM
22dodge 22dodge is offline
Vehicle: Dodge
A fuse is a circuit protection device for high current. High current is caused by excessive load or a short ciruit. you say you checked the wires? all the way from the switch to the tail lights? you pulled up the carpet, removed sill trim and rear seat?
Why did you just throw a switch at it? seems your problem is after the switch. when you hit the brakes the fuse blow./.. correct?
if you get a wiring schematic, maybe you'll see where the problem could occur (like maybe the multifunction switch
Old 11-03-2009, 01:15 PM
pdomaszc pdomaszc is offline
Talking check in your trunk
I had the same problem. The wires going to the center stop light bent as they enter trunk lid. Disconnect negative battery cable, cut the wires at least a few centimeters before the bent and separate individual cables. Connect the battery, replace the blown fuse and press stop. If the tail stop light are working you have found your problem. Some simple rewiring should do the trick, but do not attach the new wires to the plastic mount, just let them hung there. Good luck.
Intrepid with 2.7 V6 = the worst car EVER. (I have one)
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
