2002 Intrepid trouble codes what are they
My 2002 intrepid has these two faults in it. P0441 Evaporative purge flow system not working properly and P0582. Cant find anywhere what the 582 is?
My question is what exactly is the 441 and 582 faults and what my be the fix?
Also anyone know of a latest and greatest Dodge trouble code web page?
Thanks
Thanks
RE: 2002 Intrepid trouble codes what are they
http://minimopar.knizefamily.net/fault/index.html
That's the page I've been using for my '96. I'm not sure if it's exact for an 02, but give it a shot. It also shows u how to get the cars computer to tell you what your error codes are, w/o using a seperate diagnostic computer. My cruise control went out, and the car told me I had a code 34, which according to this site is a problem with my speed control solenoid.
Good luck!
Good luck!
Going through my Code reader manual, Code p0582 is Cruise Control Vacuum Circuit / Open and code p0441 is Evap Emission System Incorrect Purge flow. I would guess you have a Vacuum leak some where. Might be a loose hose. Can you here a hiss anywhere? Might be an easy fix, hope it helps, Don't forget to reset the MIL. To help you with codes in the future just go to www.codereader.com.
