2nd Gen Intrepid 1998 through 2004 Intrepids
2002 dodge intrepid se 2.7 I keep getting cam and crank sensor codes plus knocksensor
Old 03-30-2012, 04:35 PM
shellieman's Avatar
shellieman
shellieman is offline
Default 2002 dodge intrepid se 2.7 I keep getting cam and crank sensor codes plus knocksensor
I have a 2002 dodge intrepid with 2.7,, we bought the car with a broken timing chain. had replace timing set and water pump.replace the whole timing components,, here is the problem,, it starts hard, but once running it runs find but you can't rev it up and you can't take off very fast in it, if you give it to much gas it like surges or cuts in an out,, if you floor it its like it dies and then drops down in low gear.. I get three codes p0344, p0016 and p0325,,, but I have replaced both cam and crank position sensors, but still get codes for them. I would appreciate any help I can get on figuring this out.
Quick Reply: 2002 dodge intrepid se 2.7 I keep getting cam and crank sensor codes plus knocksensor
