2nd Gen Intrepid 1998 through 2004 Intrepids
High pitch squeal coming from the steering
Old 05-25-2015, 10:48 PM
97 3.5 Intrepid's Avatar
97 3.5 Intrepid
97 3.5 Intrepid is offline
Default High pitch squeal coming from the steering
My car has been making a high pitch squeal sound for a while at least 6 months, maybe longer. It is not very noticeable when the vent is running, but when it is off you can hear it. It is not a grinning/moaning sound as I have heard in numerous K based steering systems, it sounds kind of fabric/nylonish sound like someone someone trying to rub out a stain on an pair of pants. Any ideas?
I thought it might be that the power steering fluid was getting bad so (in probably a moment of stupidity on my part in retrospect), I sucked out the old fluid in the reservoir then after reading my manual and did a Google search and replaced it with ATF+4 finding a reference to a TSB stating that ATF+4 could be used as a replacement for the MS9933. I'm not sure if this is a placebo effect, but it might be slightly quieter. Should I just have the system properly flushed with ATF+4?
Old 05-26-2015, 10:04 AM
jkeaton is offline
Dodge Forum Administrator
How's the belt?
Old 06-09-2015, 12:35 AM
97 3.5 Intrepid
The belt is fine, it turns out it is the clock (spelling?) spring. No big deal.
Old 06-09-2015, 12:39 AM
97 3.5 Intrepid
Default Vibration and loud sound when using AC
Periodically when I turn on my AC (Air Conditioner) the car will vibrate significantly and it makes a sound similar to what a tractor trailer truck makes when it is engine braking. Even if I turn the AC off it will continue to do this until I shut the engine off. If I restart it (with the AC off), it will run fine. It doesn't do it everytime I use the AC, but I want to get this fixed naturally because it is becoming more frequent. Any ideas?
Old 06-09-2015, 03:47 PM
jkeaton is offline
When it does it next time, open the hood and have a look at the compressor and accessory drive belts. Possible have a pulley bad.
Old 06-09-2015, 06:50 PM
97 3.5 Intrepid
Okay, what are the signs of a bad pulley? How can you tell if it is the pulley?
Old 06-12-2015, 11:18 PM
97 3.5 Intrepid
Default It's fixed
It turns out the sound was the plastic fan blades from the radiator fan so I replaced that whole unit. While it was being repaired, I also replaced the serpentine belt and A/C belt along with the pulley just to be safe. Thanks for the help.
Quick Reply: High pitch squeal coming from the steering
