2002 Intrepid PCM Code P0441
11-11-2005, 05:26 PM
on
Check engine light is on. Received pcm code P0441. Informed possible hose or sensor. Has any one experienced this? Corrective action needed.
06-28-2008, 04:06 PM
on
RE: 2002 Intrepid PCM Code P0441
If it helps, mine was the hose. I took my 02 Intrep to a dodge dealer. May have to pull fuel tank, if you can check the hoses and replace, if necessary, yourself. Hope this helps...
05,
2000,
2002,
32,
check,
code,
codes,
dodge,
engine,
interpid,
intrepid,
location,
p0441,
pcm,
po441,
stratus
