check engine light code P0522
Old 08-22-2007, 06:45 PM
thisisrightnow's Avatar
thisisrightnow
thisisrightnow is offline
Default check engine light code P0522
I looked it up and it said:
P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
What could the problem be?
Edit. I was reading up on some threads and I read that some people had this problem when they were low on oil. I've been letting my oil get too low and I noticed my oil light came on a few times, but when I restarted, it went away. Could the fact that I am extremely low on oil cause it to spit out that code?
Old 08-22-2007, 08:28 PM
spikeymikey87's Avatar
spikeymikey87
spikeymikey87 is offline
Default RE: check engine light code P0522
try putting some oil in it to where its supposed to be. if that dont fix the problem, at least you will be keeping proper maintenence on the car, which is what you should be doing anyway
Old 08-22-2007, 10:03 PM
Mike594sxt's Avatar
Mike594sxt
Mike594sxt is offline
I dont know why, but that made me laugh.
Old 08-23-2007, 12:45 AM
neon03se's Avatar
neon03se
neon03se is offline
ORIGINAL: spikeymikey87
+1, take care of the car man lol, why would you let it go low on oil especially when you knew about it...
Old 08-23-2007, 04:06 PM
contagious19's Avatar
contagious19
contagious19 is offline
u should definetly check ur car everymonth or two
Old 04-10-2011, 08:49 AM
Criosa's Avatar
Criosa
Criosa is offline
Default same Problem p0522 AFTER sensor was changed
Okay my oil and sensor was changed about 2 months ago...well it just poped up the code..there is no oil leaking on the ground I"m not for sure what is goin on Please help
Old 04-10-2011, 06:04 PM
Moparkyle's Avatar
Moparkyle
Moparkyle is offline
Did you check your oil? Just because the oil isn't hitting the ground don't mean it ain't leakin.
Old 10-19-2011, 08:41 PM
Anteros's Avatar
Anteros
Anteros is offline
I just bought my '04 Neon 6 days ago, had the oil changed 4 days ago, I can assure you, I am NOT low on oil. This code came up, plus code P0572 /Brake switch A circuit low. Is it a fuse thing?? the engine malfunction light came on while I was driving to work, and stays on now.
any more suggestions?
Old 10-20-2011, 05:00 AM
darthroush's Avatar
darthroush
darthroush is offline
Section Moderator
Dodge Forum Moderator
Bad oil pressure sensor. $10 at Dodge. As for the P0572, do your brake lights work correctly?
Old 10-20-2011, 11:39 PM
Anteros's Avatar
Anteros
Anteros is offline
Question
Well the 522 code resolved on its' own, I checked the codes again tonight and only the 572 code is left. I checked my lights and yes, they all work correctly. What am I missing?
Quick Reply: check engine light code P0522
