Rattle from Rear
RE: Rattle from Rear
True enough but they can. Was browsing other forums and found out that other are having this problem and are filling the uppoermounts with window sealer as the rubber is not filling the upper mount properly. So it seems to be bad mounts and not anything loose. Bigger problem in cold weather and seems to go away in the warm. Found it in the SRTforums.com. Worth checking it out. You are not going crazy there really seems to be and issue cropping up.
Thanks alot. I'll bring it up to the dealer when I go in. Maybe they know something about it. It was quite a bit warmer here today. Highs were in the low 30s, which is quite a change form the subzero temps we have been having. I didn't notice the rattle as much on the drive home tonight. That would make since with what you are saying.
