--also modernperformance has a 2.4 swap... it comes with all the parts from a srt-4...the only thing i would need to do i bore out the cylinders... please check it out...www.modernperformance.com under srt-4...
thanks for the responses
those parts will not fit your motor.
If you want more power turn up the boost. I ran 14 pounds on stock motor for about 3 months before I snapped a rod.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
__________________
03 r/t-t MS powered-soon too be 2.4 pt powered
doch > soch
98 neon soch aka "the beater"
Sponsored Links
Registered users do not see this ad. Click here to register for free!
i was thinking he could go MAYBE 12 and be ok.... i would not want to blow the motor up, but that is just me.... i also had a 1500 dollar investment in my head when i went boost, stock block i really would not care if it went boom.....
as for the 2.4 swap u HAVE to change the engine to a 2.4... i thought the same thing u did until i had a performance shop say it was possible, then a race shop tell me it wasnt, along with people on this forum..... in all honesty u prolly will not notice a huge difference even if u jump the boost to 12 psi, same with the intake and throttle body.... they r just good add ons if u ask me....
__________________
car is started and running, ms install to be started very soon..
20psi street car is getting closer and closer by the day!
For a boosted car is better too built the motor and then up the boost and when you hit the max boost the turbo can get too and you still want more power then start with the add on's like t/b's and intake manifolds.
__________________
doch > soch
Vehicle: '03 Dodge Neon SE, '02 Roush Mustang, '86 Ford F150 4x4, '86 Ford Bronco 4x4
Just adding for cogs1212 (Post #8)- I have a Diablosport Predator Tuner for my Mustang and I have it on the performance tune. I must run a minimum octane of 91 and it advances the timing which is how some HP is given through the hand held tuner. So yes, timing can add power, safely, to a degree... Just some food for thought.
