DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Neon > 2nd Gen Neon
Thread Tools Search this Thread
Old 04-11-2009, 11:41 PM
batchelar batchelar is offline
the metal tubes can be very sensetive little things. they may look like they are in good condition but even a slight warpage will casue a leake or popping out. if they seem perfect go ahead try reusing them. yes replace the seals in the valve cover and replace the valve cover gasket while its off. and replace teh cam position sensor while the vc is off as well its easier that way trust me.
now to seal the tubes you can absolutly use a gasket marker. the problem wioth that is that it is an anabolic sealant meaning it never truly dries and requies oxygen to do do so. no much in the head. it is best to clean teh end of teh tube with either fine grit sandpaper or scotch bright then wipe it clean and use a little bit of red lock tight. the tubes do not need or like to be pounded into place they bend. put on a pair of gloves or rag and line them up and push hard. they all go in level and seat witha bit of force. no hammers dead blows mallets just hands. then you have a well working tube.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Tags
2001, 4, 98, diy, dodge, head, neon, oil, plug, plugs, plymouth, popped, problems, seals, spark, tube, tubes
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
