DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Neon > 2nd Gen Neon
Thread Tools Search this Thread
Old 04-22-2009, 05:23 AM
neonftw87 neonftw87 is offline
2000 Dodge Neon
not the cowl, the cavity that the cowl covers lol
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 04-22-2009, 11:19 AM
N3ON's Avatar
N3ON N3ON is offline
Vehicle: 2002 NEON(E-xtra S-pecial)
Send a message via Yahoo to N3ON
even if someone cut a hole in your firewall it would still be hard to get water through it
__________________
On the road and out the garage
Old 04-22-2009, 06:10 PM
2000 Dodge Neon
true story, i would say bottom of the windshield, you know how neons and weather stripping is lol
Old 04-22-2009, 06:12 PM
2000 Dodge Neon
i take that back guys about nothing running thru the firewall on the passenger side, the AC line run right thru the firewall where your talking about, could be getting leaks there also
Old 10-26-2009, 06:34 AM
darthroush's Avatar
darthroush darthroush is offline
Vehicle: 2003 Dodge Neon SE, 2002 Roush Mustang, 1986 Ford F150
BUMP
I had thought I posted this, but I guess not; at least not that I could find. I was just going through some stuff again and thought this might interest some people. Check out TSB 23-008-03 from 4/11/03.
__________________
Old 10-26-2009, 06:36 AM
darthroush's Avatar
DATE: Apr. 11, 2003
SUBJECT: Right Side Cowl Water Leak
OVERVIEW: This bulletin involves sealing a right side cowl seam.
MODELS: 2003 PL Neon/SX 2.0
SYMPTOM/CONDITION: Water on the right front passenger floor.
DIAGNOSIS: Run water over the right lower A-pillar with a garden hose. Remove passenger side cowl trim and pull back floor carpet to confirm water leaking into passenger compartment. If water/leak is present, perform the repair procedure.
REPAIR PROCEDURE:
1. Open Hood.
2. Remove the three screws holding the cowl grille/screen on the passenger side of the vehicle.
3. Partially remove hood to cowl seal, at the leading edge of cowl grille/screen.
4. Disengage grille/cowl screen anchor at center of cowl.
5. Rotate the right side cowl grille/screen out of the way of the cowl plenum being careful to not pull cowl grille/screen upper weatherstrip off.
6. Locate the large vertical and horizontal sealer beads near the right outboard cowl grille screen mounting screw attaching point (Fig. 1). The sealer beads are at the junction of the A-pillar, cowl plenum upper and cowl side panel. Apply Mopar Silicone Windshield & Glass Sealer, p/n 04467708, to the outer edge of all existing sealer beads.
7. Allow sealer to set up for 30 minutes. Water test right lower cowl area to verify repair. install passenger side cowl trim.
8. Reverse above procedure to install the cowl grille/screen.
__________________
Old 10-26-2009, 09:23 PM
AnthemBassMan AnthemBassMan is offline
Vehicle: 2005 Dodge Neon SXT
-Thanks for this, and what timing! I'll be doing this to my Wife's '05 Neon tomorrow morning. She's had quite a bit of water leaking form the last couple heavy downpours we had. Picked myself up a tube of 50 year, silicone sealer the other day. I thought it was from the fresh air intake being so close to the cowl plenum. I checked it out a couple weeks ago because I thought maybe the fender drains were plugged and water backed up to the intake. But everything was clean as a whistle. So I bought the sealer to go over the factory beads just to make sure. Now I know EXACTLY where to put it. Thanks again.
L8R,
Matt
__________________
Old 10-29-2009, 12:20 PM
johni86 johni86 is offline
Hi all!
I am from finland and i have this 2nd Neon 2001 and i HAVE excatly same problem with you guys!
It started when i changed my windshield this summer, i`ve been having this problem like 3 months now... Water has come like 3-6 times inside car from under dash passenger side......
I tryed to repair the problem today, I took the car with dartroush instructions and i used to fill the "place" with structural adhesive called sikaflex.
I have pictures if somebody want`s to see how did it go...
Now i am waiting for some rains to see if it works..
Just give private message to me and i will send the photos!
Regards, Joni
Old 10-30-2009, 08:33 PM
-Why wait for the rain to come? Grab a garden hose and let her flow. So far so good for me. Let's see those pics of yours.
L8R,
Matt
__________________
Old 11-04-2009, 04:45 AM
Quote:
L8R,
Matt
I send private message to you, could you read it? =)
BR, Johni
Tags
2003, coming, compartment, dash, dodge, glove, interior, leak, leaking, leaks, neon, passenger, side, sxt, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
