DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Neon > 2nd Gen Neon
Thread Tools Search this Thread
Old 04-26-2009, 02:51 PM
lilreddakota lilreddakota is offline
Vehicle: 1990 Lil Red Dakota Express,2003 Neon,1999 Jeep Cherokee Sport,1997 Dodge Caravan Sport
Talking
Just pulled pan to drain fluid, only saw Very small amount of coolant in oil. Hard to tell though with red coolant. No pink milkshake though. I think with the cooler being on the bottom of radiator the trans fluid may have sat in bottom tank and been pushed back into trans until it cooled down. Never paid attention before that the radiator is a downflow design. Put 122,000 miles on it, that is like 40 oil changes i've done myself and I didn't catch that, what WAS I looking at? LOL I am considering plugging off cooler lines at radiator and putting on an external cooler just to flush cooling system and trans out good. Then I can run it to check trans operation before I put in a radiator.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 04-27-2009, 06:10 AM
darthroush's Avatar
darthroush darthroush is offline
Vehicle: 2003 Dodge Neon SE, 2002 Roush Mustang, 1986 Ford F150
Not sure why you would need an external cooler to flush the system (maybe I misread?), but sounds like there may still be hope!
__________________
Old 04-27-2009, 10:59 AM
smallblockfreak smallblockfreak is offline
1986 Dodge Ram 150
My Garage
Vehicle: 01 dodge neon SE
Send a message via AIM to smallblockfreak Send a message via MSN to smallblockfreak Send a message via Yahoo to smallblockfreak
external cooler is a good choice because then you don't have to worry about coolant getting into the tranny ever again.
__________________
Silly Ricers Useless Wings Are For Penguins.
Old 04-27-2009, 02:36 PM
Altima_wb Altima_wb is offline
Vehicle: 97 DOHC 5spd neon sport
Send a message via AIM to Altima_wb Send a message via Yahoo to Altima_wb
yeah i would deff think about just leaving the aftermarket cooler on there... won't ever have to worry about the problem again... but it would be deff a good idea to check the function of the tranny anyway... just hope that your hoses didn't see much of that trans oil... for a safe bet i would change all the coolant hoses just to save from future problems... good time to throw in a new water pump and timing belt also if you haven't yet...
__________________
91 Chevy K1500 (current stock 305 to mildly built 350 swap in the works)
97 Olds minivan (wifes ride lol)
New Project 97 DOHC neon sport (Project daily driver :P)
Old 04-27-2009, 05:44 PM
I was figuring if I put on an aftermarket cooler I could just plug the cooler lines at the radiator to prevent coolant leaking from them to make sure trans is ok before I spend money on a new radiator. I can also flush out the cooling sysytem before I change radiator so if any crap is left in radiator it will be in the old one.
I was thinking about the timing belt about a month ago, bought used w/20,000 miles, 142,000 on car now. It has original ...... well.... everything except tires, front brakes and fluid and filters. I don't think its been a bad car yet. I was planning on changing all the hoses and might as well do the thermostat while its apart.
Old 04-27-2009, 06:52 PM
darthroush's Avatar
Ah, ok. I was just curious. I am well aware of what it does, was just wondering if there was another purpose to it such as leaving it on.
__________________
Old 04-29-2009, 01:28 PM
Quote:
Its deff time to replace the timing belt then... and always replace the water pump with the timing belt... seen as you have to drain the coolant anyway
__________________
Old 04-29-2009, 02:38 PM
N3ON's Avatar
N3ON N3ON is offline
Vehicle: 2002 NEON(E-xtra S-pecial)
Send a message via Yahoo to N3ON
+1 i have an external cooler
__________________
On the road and out the garage
Old 05-17-2009, 12:27 PM
Another snail pace update.
The steady increase in gas prices have motivated me.
Pulled trans. cooler hoses off of radiator. Ripped right side fitting out of radiator with hose. Now I have no choice but to get a radiator. Changed filter, installed pan and flushed trans with clean fluid. Hooked cooler lines together and ran it up on jackstands, after a couple attempts tranny filled all voids and runs through all gears now. Seems as if I have dodged that bullet so far. Have to see what happens when I get her on the ground and run her hard and hot.
Just ran it for a short time, coolant dripping out around broken fitting at cooler. Feel like I can spend the money on radiator/W/P/thermostat/timing belt/coolant/hoses/flush and anything else I stumble upon/break in the process with less worry about trans for now.
Need to make room in the garage for the Jeep first to change RF wheel bearing so I can hear the radio again on the way to work tommorrow.
What a crappy set up the cooler is. Cooler pops in tank from inside and the hose nipple fitting screws into it from the outside and that is all that seals coolant inside radiator and seperates coolant and trans. oil. You would think they would put a little more material around the fitting and make longer threads for it to thread into.
Old 05-17-2009, 02:13 PM
darthroush's Avatar
Blame Mitsubishi. They made the damn engine, lol.
__________________
Tags
2002, code, crack, filter, high, limpin, lines, mode, neon, nitro, p0706, po700, pressure, radiator, rupture, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
