DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Neon > 2nd Gen Neon
2nd Gen Neon 2000 - Present Neons
Thread Tools Search this Thread
Old 05-05-2009, 07:29 AM
Ghost Neon 2 Ghost Neon 2 is offline
Vehicle: neon
If you had a 1G, the 2.4 swap is the better platform. Even n/a, the 2.4 puts out 30 lbs torque over the dohc and sohc. That is the real difference. The need to rev to 7k+ for power is eliminated with this dramatic increase in low end torque. Stock 2.4 swap peak at around 5500k, which is more than enough to get the job done. Those seeking more move on to head work and cams to maximize air flow to attain usable power about the 6k mark. Taking my 2.4 apart for cleaning while searching srt rods. They are not needed for this n/a build, but added security is good with 10.5 pistons.
BTW, I have an 02 r/t head, cam, and exhaust manifold if yoiu are interested. $350 plus shipping.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
Ghost Sighting
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 05-05-2009, 09:22 AM
03bloodsxt 03bloodsxt is offline
Does anybody ever build the 2.0 A588 motor? (curious)
Old 05-05-2009, 12:05 PM
Vehicle: neon
Yes. That is not a neon engine though. The A588/420A is found in the sebring, avenger, and n/a talon/eclipse. They have relatively the same options as neons, since the block is the same. The cylinder head (has the exhaust ports up front), but has after market cai, cams, valve train, and header option to choose from.
__________________
Ghost Sighting
Old 05-05-2009, 12:47 PM
Oh, i guess i misread my research. Well does anybody build up the engine out of the 03 Dodge Neon SXT?
Old 05-05-2009, 01:51 PM
Altima_wb Altima_wb is offline
Vehicle: 97 DOHC 5spd neon sport
Send a message via AIM to Altima_wb Send a message via Yahoo to Altima_wb
Quote:
Originally Posted by Ghost Neon 2 View Post
If you had a 1G, the 2.4 swap is the better platform. Even n/a, the 2.4 puts out 30 lbs torque over the dohc and sohc. That is the real difference. The need to rev to 7k+ for power is eliminated with this dramatic increase in low end torque. Stock 2.4 swap peak at around 5500k.....
So your saying that the 2.4 has over 163 lb-ft of tq... the DOHC 2.0 in the first gens is rated at 150 and 133lb-ft.... as far as i knew the 2.4 was rated at 150 and 150... which yes 20 extra lb-ft is still pretty kick ass... but there are a few things you can do to gain a few extra ponies from a 2.4 before you drop it in... like removing the balance shafts... and if you can find a set cheap or have a set the 2.0 DOHC cams... which are bigger then the 2.4 cams... should be good for a few extra ponies to make the 2.4 swap really worth it.. besides any other bolt ons you do you will gain more from in the long run then you would with a 2.0... the 2.4 is a good base to start with if your planing on doing lots of mods... or is a good replacement if your 2.0 is dead...
__________________
91 Chevy K1500 (current stock 305 to mildly built 350 swap in the works)
New Project 97 DOHC neon sport (Project daily driver :P)
Old 05-05-2009, 01:59 PM
What would u need for the 2.4 swap. I know engine,tranny(maybe),PCM, is there nething else, fuel pump motor mounts wiring harness I would like to know everything u would need b4 i dive into this swap.
Old 05-05-2009, 02:06 PM
darthroush's Avatar
darthroush darthroush is offline
Vehicle: '03 Dodge Neon SE, '02 Roush Mustang, '86 Ford F150 4x4, '86 Ford Bronco 4x4
SO many threads on that. Take a peek around. I'm sure there are some recent ones in which you can just scroll back through some pages...
__________________
Old 05-05-2009, 02:10 PM
the 2.4 bolts right to the 1st gen SOHC or DOHC tranny so tranny shouldn't be an issue... go into the first gen forums that will give you an idea of what it takes in a first gen... there should be some thread about srt4 swaps which should be simular...
__________________
Old 05-07-2009, 06:55 PM
jamesmsta jamesmsta is offline
Vehicle: 2004 dodge neon r/t
just sell your neon and buy an srt4, you wont make power swapping the motor. you need the entire srt4 set up. you wont be happy going to the 2.0 magnum (i have an 04 r/t with it) its weak on power but better than a stock 2.0, but barely. they built the srt4 so neon owners could spend less money to make there neons fast. sell your car buy an srt4, it will save you alot of money and time.
Old 05-07-2009, 07:45 PM
darthroush's Avatar
I think that depends. Is the car paid off?
__________________
Tags
20, 2000, 24, a588, dodge, engine, engines, magnum, motor, neon, pcm, run, stratus, swap, viper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
