DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Neon > 2nd Gen Neon
Thread Tools Search this Thread
Old 05-04-2009, 05:33 PM
mark89coupe mark89coupe is offline
Default Battery won't charge
I have a 2000 Neon, automatic.
I replaced the battery and took the alternator out and had it tested and it is good. What other places should I look if the battery is not charging?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 05-04-2009, 06:40 PM
darthroush's Avatar
darthroush darthroush is offline
Vehicle: 2003 Dodge Neon SE, 2002 Roush Mustang, 1986 Ford F150
Check the wires to and from each of those items?
__________________
Old 05-04-2009, 09:38 PM
I found one and it goes to the starter. I will trace the other.
Is there a voltage regulator?
Old 05-05-2009, 12:48 AM
darthroush's Avatar
Hmmm, not that I am aware of? Always a possibility though. Hard to say without the manuals in front of me...
__________________
Old 09-08-2009, 03:05 PM
I can get the car running and it stays running. When I turn on the wipers or anything the car stops running instantly.
Any other suggestions?
Old 09-16-2009, 10:13 PM
neisg1 neisg1 is offline
Vehicle: 2001 Chrysler Neon LE
Default Voltage regulator
The voltage regulator is built into the PCM. Are you getting any warning lights or check engine codes? Check the battery voltage while running, if it’s charging it should read around 14 to 14.5 volts. Check all the battery and alternator wiring connections including the alternator ground.
Old 09-18-2009, 01:45 PM
mjs182004's Avatar
mjs182004 mjs182004 is offline
Vehicle: 2008 Hyundai Tiburon
Send a message via AIM to mjs182004 Send a message via Skype™ to mjs182004
You might have just got a bad battery. I would get it tested.
__________________
08 Hyundai Tiburon, also a 91 Cadillac Brougham d'Elegance===> http://www.cardomain.com/id/mjs182004
Tags
2008, alternator, avenger, battery, charge, charging, davidson, dodge, good, harley, neon
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
