HELP! CAM Sensor Problem
Hi,
My Neon keeps giving me a sensor problem code of P0344, which is the CAM sensor. I replaced the sensor, and the car ran fine for a day, and then the check engine light came back on. Whenever the light is on (which is constantly now), the cruise control won't work either. After doing some research, I checked to see if oil was behind the sensor and disrupting it. It was covered in oil, so I cleaned it and put it back on. The car drove fine for about 30 minutes, and then the check engine light came back on and the cruise control stopped working. The car also runs pretty rough. Yet, I'm still getting the P0344 code. We also checked the PCV valve to see if it was clogged, and it wasn't. I don't know what else to do. Is there a seal perhaps that I can replace to stop the oil from getting behind the sensor? The Associates at AutoZone didn't know of one, but nothing else makes sense. Any help you can give me would be greatly appreciated.
Jason
Jason
