DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Neon > 2nd Gen Neon
Thread Tools Search this Thread
Old 08-04-2009, 01:47 PM
srt4rez srt4rez is offline
Vehicle: 04 Silver Srt-4,Kinetic Wastegate,K/N CIA Typ,AGP OCC,Black Drifter rims w/ Falken tires,Prosport Ga
Default Squeaky rear brakes
Recently, I've been plagued with the squeaky rear brakes and when I checked them, there seems to be no wear to the metal. I heard most neons tend to do this. Anybody know of a remedy??? (sometimes it gets embarassing, due to the high pitch noise) I would like to switch to a rear disc, rather than the rear drum. Thank you, any suggestions will be helpful.
This is for 04 SXT Dodge Neon-Stock...
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
SRT-4/The few,the proud,stock for stock..fast!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-05-2009, 01:41 AM
Tman52 Tman52 is offline
Vehicle: 2002 Neon SXT
I had a squeaky noise coming from what I thought was the rear brakes too, took it in and turned out to be that the front rotors were close to being bad and needing replaced.. They were replaced problem solved, check your front rotors.. then check back in and tell me the results..
Old 08-05-2009, 01:42 AM
Oh, and they weren't "Bad" but they were close, and dodge installed something that made the embarrassing squeaky noise to tell you to get your rotors replaced..
Old 08-05-2009, 05:40 PM
deranged's Avatar
deranged deranged is offline
2001 Dodge Dakota
My Garage
Vehicle: 01 Dakota
Clean the brake assembly up and then put some grease on the contact pads where the shoes ride against the backing plates. That is probably what is causing the squeaking.
__________________
Marvin L DeJaynes
Old 08-06-2009, 02:44 AM
darthroush's Avatar
darthroush darthroush is offline
Vehicle: 2003 Dodge Neon SE, 2002 Roush Mustang, 1986 Ford F150
You will have to take them apart and grease the six pads where the shoes rub, as said above. That should take care of it unless it is something else.
__________________
Old 08-06-2009, 06:52 PM
Thanks for the suggestions guys, I'll check it out. Hey darthroush, notice that you have a 1986 Ford f-150. Is it a 302 with a fuel injected? That's what I have too. I have a question about the truck, even though this is not a ford forum. I think, when mines gets hot, it shuts off and then restarts normally when it cools off. Have you ever had that problem? Let me know of the situation.
__________________
Old 08-06-2009, 07:29 PM
darthroush's Avatar
My truck has the 4BBL 5.8L 351W HO engine actually The 86 Bronco however has the FI 302. I've never had that problem, but have heard of it before. Let me see if I can try and find out what it was later.
__________________
Old 08-07-2009, 10:39 AM
Thank you, I would appreciate that very much!!
__________________
Old 08-11-2009, 03:45 PM
darthroush's Avatar
Have not forgotten about you. Just been really busy and have not had time to research it yet.
__________________
Old 08-11-2009, 03:52 PM
darthroush's Avatar
OK, got some things from a few places. This first one is what I hear more frequently, but doesn't mean that it is the fix.
Quote:
check for spark when the car shuts down. I'm willing to bet it doesn't have it. If it doesn't I'd look towards the ignition module, or the coil pack.
In our case, the coil itself.
From someone else in that same thread:
Quote:
Also read elsewhere that you can't check for spark when this happens since a CPS failure apparently shuts down the ignition system.
From a different thread:
Quote:
All "crank, no start" conditions are approached in the same way. Every engine requires certain functions to be able to run. Some of these functions rely on specific components to work and some components are part of more than one function so it is important to see the whole picture to be able to conclude anything about what may have failed. Also, these functions can ONLY be tested during the failure. Any other time and they will simply test good because the problem isn't present at the moment.
If you approach this in any other way, you are merely guessing and that only serves to replace unnecessary parts and wastes money.
Every engine requires spark, fuel and compression to run. That's what we have to look for.
These are the basics that need to be tested and will give us the info required to isolate a cause.
1) Test for spark at the plug end of the wire using a spark tester. If none found, check for power supply on the + terminal of the coil with the key on.
2) Test for injector pulse using a small bulb called a noid light. If none found, check for power supply at one side of the injector with the key on.
3) Use a fuel pressure gauge to test for correct fuel pressure, also noticing if the pressure holds when key is shut off.
Once you have determined which of these functions has dropped out,
you will know which system is having the problem.
I will take a look around again later and see if I can find more, but it's a start I suppose.
__________________
Tags
03, 2003, 2004, assembly, brake, brakes, dakota, dodge, f150, neon, pic, rear, squeaking, squeaky, sxt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
