DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Neon > 2nd Gen Neon
Thread Tools Search this Thread
Old 08-29-2009, 01:27 AM
neisg1 neisg1 is offline
Vehicle: 2001 Chrysler Neon LE
Default Axle whench size
Anyone know off hand what size socket is required to remove the drive axle hub nut on a 2001 Neon?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-30-2009, 12:55 AM
darthroush's Avatar
darthroush darthroush is offline
Vehicle: 2003 Dodge Neon SE, 2002 Roush Mustang, 1986 Ford F150
Somewhere around 26MM I think. Can't remember the exact size.
__________________
Old 08-30-2009, 01:51 PM
Ghost Neon 2 Ghost Neon 2 is offline
Vehicle: neon
32mm axle nut socket
__________________
FS: Ported sohc heads for sale $255 shipped
Known mtx supplier for neons
http://www.youtube.com/watch?v=7-FRLtr35ZA
Old 08-31-2009, 02:28 AM
darthroush's Avatar
Must be different on the 00-02's then (I do not have a socket that big, but got mine off with the correct size one), or I'm thinking of the wrong thing.
__________________
Old 09-02-2009, 10:14 AM
Default axel nut
32mm sounds about right, I think I only have a 30mm so will have to pick one up.
Thanks
Old 09-02-2009, 11:44 AM
Vehicle: neon
Quote:
32mm axle nut for the front. 30mm for the rear.
__________________
Old 09-05-2009, 05:40 PM
Default Wheel Bearing done
Thanks guys the front axel nut is 32mm. and back is 30mm.
I did one front wheel bearing. both rotors and pads plus added grease nipples to the ball joints.
Another point is the ball joint grease nipples "ZERK" fittings are 1/4" x 28 taper thread, 6mm screw in but won't tighten. NOTE: if you add these do not over grease one or two shots every 5000-10000km is lots.
To do the bearing, I picked up a 12 ton press at Princess Auto on sale for $129.00CDN, I would have paid more that that in shop labor.
Tags
1996, 2003, 2007, 97, axle, bearing, dodge, drive, hub, neon, nut, size, socket, sockets, srt, stratus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
